Hard to ready but very interested. Any updates?
Arduino powered home environmental system
Originally posted by jetkit View PostHard to ready but very interested. Any updates?
I'm waiting on the Beta Arduino to see if I should update to see if the changes will solve some problems I'm having. Last attempt set me back. I've been watching the beta.
No sense in writing events until I update. It will be good to share and get more opinions for that too. There is a wealth of different ways to make the events more simple and I hope this project will tap into that, and learn a lot. From reading other topics there are a lot of pro's that could light the way, I just need to display the problem. I will need help sorting out the questions to ask.
Math I hope gets better, and the update might fix it I posted the functions and the question but no bites yet. I don't know how to sort out the math, There must be another way but I'm not a coder,and I know I need to learn some.
Jitter on the output to the servo has burned one out, but If a relay is used in series with the 5 volt power feed and activated before and after moving I have prevented another burning out. This might be fixed in the beta update
It got real cold here -8F and the windows steamed up because I can't read humidity in the house yet.
Most times the furnace manages the humidity, and provides a discreet value to HS3 but with the big drop the HRV should have run more, but it ices up fast and it would be good to set a timer using the temp probes to recognize the defrost mode and run until the humidity drops to the proper vale for the outside temperature. I have observed how this could be done.
I'm using a simple timer by way of HS3 that is easily defeated when the HRV goes into defrost mode.
Let see what a few days off brings for me and I'll see about posting, I have all the materials, now the time, thanks for the knock, I needed it.
I'm running 3 arduinos by way of the network and they have been rock solid. I would reckon 30 IOP's, and 12 of 1 wire temp, 6 analog. 2 servo. Solid communications.
I'm working on my PC now, so posts should be WSIWUG. easier to read.
