Input problem [SOLVED]
    Hi,
    I have problems with the input signals. They switch on and off, but also when I do not want to ....
    My longest cable (utp6) with a switch is 25 meters from the Arduino located and, I think, and the cable picks up disturbance.
    Now I want to change the input method to:
    If (input signal == LOW)
    wait for 500ms
     if  (input signal still is LOW)
     send status to homeseer
    else
    do nothing with this input
    If this is implemented in the sourcecode I prevent that a wrong (peak) signal will activate some events in homeseer and wake me up at 3am....
    I already set the debounce but this makes no difference (tried it with 5000ms in homeseer and in the arduino code, but switch is directly on in homeseer)
    I did also some hardware on the input (10nF to ground,100R to +VDD , 10uF over the input.) but no real changes.
    The Arduino sees less then 3V as a zero and here is the problem, peaks can be also negative and so less then 3V.
    So I tried to solve it in the software from Greig.
    If anyone has the same problem they can solved with only a few lines of code (the bold one).
    Find the Input Setup-part in the homeseerboardXX.ino, and change into:
    //*********************************Input Setup*******************************
    byte InPinArray[30] = { 0 };
    byte Debounce = 300;
    byte count = 0;
    byte NoOfInPins = 0;
    int InStateArray  [(sizeof(InPinArray) / sizeof(InPinArray[0]))];
    unsigned long PrevDebounce [(sizeof(InPinArray) / sizeof(InPinArray[0]))];
    void InputCheck() {
      byte pinread;
      byte pinread2;
      for (count = 0; count < NoOfInPins; count++) {
        if (millis() - PrevDebounce[count] > Debounce) {
          pinread = (digitalRead (InPinArray[count]));
            for (int w = 0; w < 10; w++)
              //******* modification for  input errors **************** 20151026 Alex Houben
              delay (1);
              pinread2 = (digitalRead (InPinArray[count])); //digital read is approximately  9ms
              if (pinread != pinread2)
                return;
    Compile it with Arduino1.5.6-r2, upload and ready.
    Now it runs for 2 weeks and now no more waking up at night anymore!
    Me so happy!
    Alex
    The new beta supports this. It is in the updater.
    Greig.
    Sent from my SM-G925F using Tapatalk
    Scripts =
    Various
      Greig.
      Hi Greig,
      Correct my if I am wrong but you are talking about this part:
       if(millis() - PrevDebounce[count] > Debounce){
            if (InStateArray[count] != pinread && WaitForAck == false){
              InStateArray[count] = pinread;
              PrevDebounce[count] = millis();
              Send(BoardAdd);
              Send(" I ");
              Send(count+1);
              Send(" ");
              Send(pinread);
              Send();
              WaitForAck == true;
      If I see it well then you only wait for the debounce, but what happens if there is are spikes how have HIGH's and LOW's during or directly after the debounce?
      With this there is not compare during the read. Is it not better to combine debounce and compare?
      Situation button pushed:
      - wait for debounce is finished,
      - read input a few times
      - if input still the same after this few times then input value is valid
      Situation spike:
      - if input has a different values the input value is invalid -> do nothing
      Alex
        No this is the old code. Is this the .99 sketch? If so then it has not updated properly and I will need to look at this build.
        Scripts =
        Various
          Originally posted by dreambox View Post
          Hi,
          Alex
          Hi Alex, I had had similar problem. Tried with capacitor, resistor+capacitor, debunce... my solution: optocoupler! (1N35)
            Have you tried beta .99?
            Scripts =
            Various
              Hi Greig,
                      Send(BoardAdd);
                      Send(" I ");
                      Send(count+1);
                      Send(" ");
                      Send(pinread);
                      Send();
                      WaitForAck == true;
              Situation spike:
              Alex
              I can confirm that this is the old code. It is definitely different in .99. I can also confirm that with .99 I have been unable to get a bounce with any testing.
                Hi Greig,
                not already tried beta .99, but my problems was generated from spikes (checked on oscilloscope). Optocoupler solve the spikes problem (I work with 12V on long cable...).
                The only issue that I can report, is a random delay in response: sometimes i push button and I have to wait about a second to change the status (light on or off).
