LCD refreshes on reset only?
  • LCD refreshes on reset only?
    Hi, 1st of all, Greig, thank you for adding the LCD module, I can see this being extremely useful.
    I just tried it on a genuine Uno with genuine ethernet shield. There is nothing else on this board.
    I added the LCD pin, and tried sending some text. The LCD only refreshes when I press the reset button on the Uno. If I change the text in HS and press submit nothing happens.
    A couple of times, the display has refreshed at about 1 character per second with garbage.
    Then when I reset the board, it displays the correct text.
    I am using plugin v85 with v84 sketch.
    cheers,
    Al
    Hi Al.
    I would first suggest upgrading to the v99 plug in as there is a lot of LCD changes from v85.
    Greig
    Sent from my SM-G925F using Tapatalk
    Zwave = Z-Stick, 3xHSM100 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
    Scripts =
    Various
      Will do - thanks Greig. Is the v99 plugin backwards compatible with the v84 sketch for inputs, outputs, PWM and Onewire, or do I need to update all the boards at the same time?
      cheers,
      Al
        Unfortunately you will have to update as there is changes in the board sketch that may stop things working.
        Greig.
        Scripts =
        Various
          I upgraded to v99, and still the same issue. It could be a fauly LCD module I suppose, but what failure would cause it to only work when reset.
          If I send text to the LCD, then after about 1 minute, the board goes "disconnected" and needs a reset to reconnect.
            What board are you using and what pins are connected? Also what is written on the LCD driver on the back.
            Greig.
            Scripts =
            Various
              Hi Greig, hopefully this photo tells all.
                Ok this all looks fine to me.
                Can you remove the LCD from the plugin by pressing the red x on the config screen then add it again as I am not sure the changes in .99 have stuck. If this is not working can you get me a debug log with you setting one of the lines to the word "Test" and then send it to me so I can see what is going on.
                Greig.
                Scripts =
                Various
                  I tried that, and also removing the board and re-adding it. Still the same problem.
                  I've attached a debug file. The LCD is board 4.
                  I started logging
                  reset the board
                  sent "test" to line 1
                  waited until it had "Connection Failed"
                  stopped logging.
                  Al
                    Hi Al,
                    I am at work at the moment so just had a quick look. It looks like the board watchdog is not starting and it is getting confused. Can you try adding 1 input and 1 output and then try the lcd to see if this kicks it in to life.
                    I will have a deeper look when I get 5min.
                    Greig.
                    Scripts =
                    Various
                      Al.
                      If you do not mind can you send me the sketch you uploaded to the board to.
                      Greig.
                      Scripts =
                      Various
                        This old problem has resurfaced for me on v129.
                        The LCD has been happy working for a year, (not sure what sketch version, might have been earlier than v129). I uloaded a v129 sketch over the weekend, and now the board refreshes the LCD once on startup and then disconnects a minute later. If I remove the LCD pins in the plugin, then then board stays connected.
                        Debug log attached. The LCD board is Board5.
                          Anyone else had this issue? Is it fixed in .131?
                            I upgraded to .131 but still does the same.
                            Greig, we exchanged emails about this in Dec 2015, but I can't see how we resolved it - whether it just started working, or whether I had to modify the sketch.
                            Can you remember?
                              Can you remember?
                              Did you not have to add in input and output pin or something strange like that? Is the LCD Address correct?
                              Greig.
                              Scripts =
                              Various
