pullup resistor
  • pullup resistor
    Hi, How can I set the pullup resistor in HS3?
    Enrico
    Enrico
    Are you talking about for inputs? If so they are set by default.
    Greig.
    Scripts =
    Various
      Greig.
      Yes, Thank you Greig
        Hi, do you mean all digital inputs are configured as INPUT_PULLUP?
        Sent from my Nexus 5 using Tapatalk
          Yes.
          Sent from my SM-G925F using Tapatalk
          Scripts =
          Various
            Great, no need for external resistors then :-)
              Yes.
              Greig, does that include the OneWire DS18B20 temperature sensor? Everything I have read says to wire it up with a 4.7K pull up resistor. My next hook up to my Mega is this sensor in a waterproof enclosure to measure the outside temperature at my home. Make it a more simple job without the resistor if I can get away with it.
              Chuck
                Chuck
                you will need the 4.7k resistor fore the onewire bus.
                Greig
                Scripts =
                Various
