Arduino Ethershield W5500
    I was wondering, since this shield consumes less power then the cheaper w5100 shields.
    Would this work with the arduino plugin, or does it need different libraries and code ?
    http://www.aliexpress.com/item/free-...c-dea7ccc9c614
    Been using an Arduino Ethernet Shield 2 from arduino.org for a couple of months now.
    This uses the Wiznet W5500 just had to use the ethernet2 library and modify the sketch to get it working.
    #include <Ethernet2.h>
    #include <EthernetUdp2.h>
      Thanks BS85,
      i think ill just have to see if it works then when i order the China pcbs and use the other libraries.
      Will report if it comes to this
        I have just tested the V2 Ethernet library but it is not backward compatible with the v1 shield so I can not update the this. You can change it in the sketch before uploading to the board and it will run the same.
        Greig.
        Scripts =
        Various
          Greig.
          Thanks Greig
