Raspberry PI that works with the Arduino Plugin is in beta.
  • Raspberry PI that works with the Arduino Plugin is in beta.
    Hi Greig,
    I have with my father (his is a programmer) created a program that works with your plugin. but on a Raspberry PI.
    It is programmed in Pyton and is in beta at the moment - but it works.
    If you are interested can have the code for distribution and sharing in the Homeseer community.
    It works with your version 1.0.0.36
    Hi Jacob. What is it doing if it is not for on the PI?
    Sent from my SM-G925F using Tapatalk
    Zwave = Z-Stick, 3xHSM100 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
    Scripts =
    Various
      Basically it is a pyton transcript of you API sketch.
      Ie. it opens a connection to your plugin an simulates an Arduinio API board.
      You then have to program your own stuff in the RPI Pyton-code to communicate with the Devices created in your pluginpage.
        That sounds nice Jakob, i thought there was someone that has made a arspberry plugin but not sure.
        Might be wrong.
          Might be wrong.
          no idea.
          Now it is there and the Arduino plugin is quite nice so we used that as the host for getting data.
            Jakob
            Nice job mate......that I would be interested in. I've been buying various arduino boards and having mixed results with them working....
            I'm playing with some NFC code on an arduino to use for access control, using a PI with API like code could be a better alternative :-)
            Cheers..Pete
            HS 2.2.0.11
              Would be interested in exactly the same application
                Might be wrong.
                I wrote a python script that communicates with HS via the JSON and command interface. It is not really a plugin, but does the job nicely
                link
                  Hi Jakob
                  Is it possible to get the code for the RaspberryPI, I'd like to have a look at it and maybe use it myself.....
                  Thankyou..Pete
                  HS 2.2.0.11
                    Originally posted by petez69 View Post
                    Hi Jakob
                    Thankyou..Pete
                    I'd be interested also
                    Sent from my iPhone
                    Tom
                      This sounds exactly what I'm looking for. I'm trying to keep hs running on Windows, but access the gpio ports of multiple pi's on the network. Did anyone get this working?
                        Not heard from Jakob at all.....
                        HS 2.2.0.11
