** Moved this to feature request thread.. **
Hi Greig
I've ordered myself a Weigand card reader to use as an access control system on my house. The reader will do all of the authentication in a standalone form however it has D0 and D1 outputs to interface with the Arduino.
http://goo.gl/4se6gh
i've had a good look around and there appears to be some very good weigand libraries to do the reader management.
https://github.com/monkeyboard/Wiega...ry-for-Arduino
https://github.com/ugge75/Wiegand-Pr...uino-MEGA-2560
I'm going to use your API function to see how this thing works (when all of the parts arrive).
Reason I ask this, if I use the API, its going to limit the use of the board longer term. If the library works well and makes Weigand interfacing easy, would you consider adding it to your base build ? Reason for the interface is to read the card ID and then "personalise" the house upon entry depending on what card entered the house ie: lighting, music, aircon etc....
Thanks Pete
Hi Greig
Thanks Pete
