SOLVED
I am having the exact same problem. Any ideas on what the cause is?
SOLVED by instaling the latest beta.
Constant message in the HS Log
Consistent Log message appears if I have normal logging turned on..does anyone know what may be wrong? I can disable the plugin from logging however its probably best to identify the cause.
I searched the forum and it looks like some others are also seeing the issue and that there may be a new fix in a beta version? I just checked and I'm running V1.0.0.36
May-03 6:21:35 PM Arduino Plugin Exception in RecievedText: Object reference not set to an instance of an object.
May-03 6:21:32 PM Arduino Plugin Exception in RecievedText: Object reference not set to an instance of an object.
May-03 6:21:29 PM Arduino Plugin Exception in RecievedText: Object reference not set to an instance of an object.
I only have two boards both to log Humidity and Temperature, they serve no other function at this time..Tags: None
