Analog calculations
  • Analog calculations
    I have started to experiment with analog input calculations and found 2 issues.
    1.
    If I try to use brackets in the calculations like this : (Value-120)*100/850
    Then I get this error:
    Arduino Plugin Exception in RecievedText: Conversion from string "" to type 'Double' is not valid.
    2.
    If I try to change the unit and put back "%" - then it displays "%25" instead of only "%".
    (I'm using Norwegian keyboard settings, but English(europe) regional settings.)
    1.
    2.
    what plugin version are you using?
    I have a new version that is in testing to fix lots of calculation bugs on the Analog inputs.
    Greig.
    Sent from my SM-G925F using Tapatalk
    Zwave = Z-Stick, 3xHSM100 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
    Scripts =
    Various
      I'm using 1.0.0.36
      Sent fra min E6653 via Tapatalk
        OK I would suggest using the beta that is I the updater. All of the above should be fixed in it. I will be rolling this up the the release soon.
        Please check the IDE version you are using with this to and update the libraries.
        Greig.
        Scripts =
        Various
          I manage to some how get what I want by removing the brackets. although the calculation is not correct mathematically I achieved what I wanted.
          Although without "%"
          Anyway, I did try the latest beta 103. but compiling the code returned error:
          C:\Users\HSuser\Documents\Arduino\HomeseerBoard2\HomeseerBoard2.ino:16:17: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
           char* Version = "1.0.0.101";
          C:\Users\HSuser\Documents\Arduino\HomeseerBoard2\HomeseerBoard2.ino: In function 'void InputCheck()':
          C:\Users\HSuser\Documents\Arduino\HomeseerBoard2\HomeseerBoard2.ino:89:19: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
                   Send(" I ");
          C:\Users\HSuser\Documents\Arduino\HomeseerBoard2\HomeseerBoard2.ino:91:17: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
                   Send(" ");
          C:\Users\HSuser\Documents\Arduino\HomeseerBoard2\HomeseerBoard2.ino: In function 'void AnalogueCheck()':
          C:\Users\HSuser\Documents\Arduino\HomeseerBoard2\HomeseerBoard2.ino:121:21: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
                     Send(" A ");
          C:\Users\HSuser\Documents\Arduino\HomeseerBoard2\HomeseerBoard2.ino:123:19: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
                     Send(" ");
          C:\Users\HSuser\Documents\Arduino\HomeseerBoard2\HomeseerBoard2.ino: In function 'void OneWireCheck()':
          C:\Users\HSuser\Documents\Arduino\HomeseerBoard2\HomeseerBoard2.ino:187:25: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
                       Send(" Rom ");
          C:\Users\HSuser\Documents\Arduino\HomeseerBoard2\HomeseerBoard2.ino:190:54: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
                         if (tempDeviceAddress[i] < 16) Send("0");
          C:\Users\HSuser\Documents\Arduino\HomeseerBoard2\HomeseerBoard2.ino:193:21: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
                       Send(" ");
          C:\Users\HSuser\Documents\Arduino\HomeseerBoard2\HomeseerBoard2.ino: In function 'void DataEvent()':
          C:\Users\HSuser\Documents\Arduino\HomeseerBoard2\HomeseerBoard2.ino:417:19: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
                   Send(" I ");
          C:\Users\HSuser\Documents\Arduino\HomeseerBoard2\HomeseerBoard2.ino:419:17: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
                   Send(" ");
          C:\Users\HSuser\Documents\Arduino\HomeseerBoard2\HomeseerBoard2.ino:428:22: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
                 Send("Version ");
          C:\Users\HSuser\Documents\Arduino\HomeseerBoard2\HomeseerBoard2.ino:430:15: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
                 Send(" ");
          C:\Users\HSuser\Documents\Arduino\HomeseerBoard2\HomeseerBoard2.ino:432:18: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
                 Send(" HS3");
          C:\Users\HSuser\Documents\Arduino\HomeseerBoard2\HomeseerBoard2.ino:435:24: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
                 Send("Connected ");
          C:\Users\HSuser\Documents\Arduino\HomeseerBoard2\HomeseerBoard2.ino:563:20: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
                 Send("Alive ");
          C:\Users\HSuser\Documents\Arduino\HomeseerBoard2\HomeseerBoard2.ino:589:23: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
                 Send("Reseting ");
          C:\Users\HSuser\Documents\Arduino\libraries\LiquidCrystal_I2C\I2CIO.cpp:35:26: fatal error: ../Wire/Wire.h: No such file or directory
           #include <../Wire/Wire.h>
          compilation terminated.
          exit status 1
          Error compiling for board Arduino/Genuino Uno.
          the final error code claims wire.h is missing. In library manager the wire library is said to be installed but I cannot find wire.h anywhere. especially not as part of the libraries distributed with the plugin.
            are you using Arduino IDE V1.6.8?
            Greig.
            Scripts =
            Various
              No, I was not. Downgraded now and retried. but still get the same error.
              the 1.0.0.36 code works fine (besides some warnings)
                OK As I said in post #4 you need to check the IDE and libraries you are using as they have changed from V1.0.0.36.
                If you get stuck again give me a shout.
                Greig.
                Scripts =
                Various
                  I'm now using .8 and libraries from .103, but I still get the errors.
                    That is strange. I have just updater the beta to .110. Please try that and see if it helps.
                    Greig.
                    Scripts =
                    Various
                      I saw that the file where this was referenced was not part of the latest library.zip so i tried to edit the file and removed ../wire/ and left include "wire.h" in I2CIO.cpp in the LiquidCrystal_I2C folder.
                      that did the trick and the sketch is now compiling.
                      Thanks!
