Basics needed to get started with Arduino
  • Basics needed to get started with Arduino
    Hello,
    just getting stated with Arduino and want to start off and make some lux sensors that would report to HS3
    What would the basics I would need to get started?
    would I be able to hook the Arduino's up to my RPI's?
    Thanks!
    Originally posted by csellebrecht View Post
    Hello,
    Thanks!
    I would suggest you get a Arduino Mega to start with.
    Are you saying you are running the Linux version of Homeseer on your RPI's? If so then you will need an Ethernet shield to as you can not connect them with USB.
    Greig.
    Scripts =
    Various
      I have it installed on one of my RPI's just to test out but my main hs3 is running on a win 10 box.
      looking for the least expensive way to getting into Arduino. Once I learn more and get things working I will upgrade to the best.
      I just want to try to get some lux sensors working.
        Can I connect USB to windows 10 box?
        What else would I need the board, power and sensor?
        Sent from my SM-G900V using Tapatalk
          Ok so I would just get an Arduino mega and run it USB on your Win 10 Box to start with.
          If you want to use Lux sensors there are lots of ways to do this but something like This should work without any coding.
          Greig.
          Scripts =
          Various
            Yes Just the board a sensor and some wires to connect it all up.
            Greig.
            Scripts =
            Various
              awesome thanks a lot!
