1st time set-up questions
  • 1st time set-up questions
    Hello!I just purchased the Arduino plug-in. I am trying to do a fairly basic sketch using an ultrasonic sensor to measure distance. There are outputs from the sensor that are "trigger" and "echo".
    Questions:
    1. I would like to see the value on the HS3 device list. Do I set up a range of values for this?
    2. Would echo and trigger be inputs, or outputs?
    3. Is there a way to make a graphic output?? I'm using this to measure distance to the top of water in a tank.
    Thank you in advance!
    Questions:
    Anyone have any thoughts on this?
      Hi NPMAN,
      What sensor are you using? is it this one
      If so then you will need to add this sketch to the API.ino and set up the two inputs to Homeseer. This will then give you the values in HS devices.
      There is no graphing option in this plugin but Jon00 has some great scripts you can run to do this.
      Greig.
      Scripts =
      Various
        Originally posted by enigmatheatre View Post
        Hi NPMAN,
        Greig.
        The ultrasound device that I am using is an HC-SR04
        http://www.micropik.com/PDF/HCSR04.pdf
        It uses 4 pins, as opposed to 3.
        Thanks for your help Greig!
          If you use this and the API.ino then it should work.
          Greig.
          Scripts =
          Various
            Greig.
            Thanks Greig! I will try this tonight
              Greig,
              First thank you so much for this plugin. My wife hates you, but only because I have boards, wires and sensors all over my office playing with this. It really is addictive and I stay up all hours of the night with the projects.
              I have 10 onewire temp sensors, h-bridge, water sensors, relays all working and now I'm looking at HC-SR04 ultrasonic ranging sensor for a well water storage tank, salt level in water softener, and several garage application to detect car in garage, door open, etc.
              If I understand your response in this thread the way to implement is to use API mode and add the applicable sketch to API.ino. Is this still the case? Is ultrasonic ranging support planned in a future plugin release, or not technically feasible?
              Guy
