Ethernet Connection problem
  • Ethernet Connection problem
    I have upgraded to the latest plugin and sketch. V1.0.0.115 and V1.0.0.112
    Within one minute i get "connection failed" on my two uno unit's
    Power toogle of both uno will restore the Ethernet for 30 sec then "connection failed"
    I had this problem Before about 8 times per year.
    When is goes into connection failed i can still ping the unit?
    The Ethernet module i'am using is a small red board with the chip 5100 works with standard lib.
    Changes to the plugin and sketch made my modules unusable.
    Some issues here as well.
    I updated to the new beta. USB board disconnected, then downloaded the new .ino file but arduino ADK could not upload the new file. When I restarted the server, the board was working OK. it has not failed yet.
    That said I have not tested my ether boards and the Arduno UNOs are not having none of that! (they fail each time you try to upload the .ino file)
    Eman.
    The Closer.
      Can you both check that the plugin is finding and using the correct gateway and subnet on the configuration page and in the Sketch.
      Greig.
      Sent from my SM-G925F using Tapatalk
      Scripts =
      Various
        gateway and subnet seem ok, I have also reloaded the sketch to both uno's same problem. i'am using arduino 1.6.9 to program with.
        I still can ping both units even if they have Connection failed in homeseer.
          OK that may be the problem It says to use IDE to 1.6.8
          Scripts =
          Various
            same problem with 1.6.8
              I am having the same problem. I upgraded to get rid of an exception error and now having trouble staying connected.
                Don't mean to be a pest but any progress on this? I deleted and reinstalled the libraries, the IDE, and the sketch but still having the same issue.
                Thanks.
                  This is a bigger problem that I thought. I need to work on a fix for it. For now I have updated the Beta page to have links so you can roll back if you need to. I would suggest .112 available Here.
                  Greig.
                  Scripts =
                  Various
                    Hi Greig,
                    Thanks for your reply. I clicked on the link on the beta post and got a txt file. How do I roll back to 112?
                    Art
                    I figured out how to extract the link from the txt file. Here it is:
                    dl.dropbox.com/u/7189079/Homeseer3/Arduino/Arduino_1_0_0_112.zip
                      There is no need to install this manually. Just add the updater_override.txt file to your Homeseer root folder then go to the updater and update the listings. The plugin will show as the only on in the updater with the version you wanted.
                      After install delete the updater_override.txt file to restore the updater to normal use.
                      Greig.
                      Scripts =
                      Various
                        Hi Greig,
                        Given the problems with downloading the sketch file (see thread 'Cannot create API.ino') I also want to rollback to i.e. 112. I got the updater_override.txt file and put it in the HomeSeer root. In the plugin manage page I did a update listing but it does not work. See the image.
                        Am I doing something wrong?
                        I am using now version 117.
                        regards, Cor
                          Greig,
                          I deleted everything and tried 112 and I am having the same issue. Cannot keep a connection and to get a connection I have to unclick and click the Automatic Connection tick box. Pressing Connect does not work.
                          I am going to switch to the USB/Serial connection for now. Hopefully that will be reliable.
                          Let me know if you need me to send you logs.
                          Art
                            Same problem with 112.
                              Please try V .118 and see if this fixes your problems
                              Greig.
                              Scripts =
                              Various
