I've been following the "ethernet connection problem thread" with great interest. I've been having similar issues regardless of version using the API ino running two Freetronics Ether10 and one Ethermega. I've never been able to connect more than one board simultaneously and when a single board does connect it drops with a couple of hours. Once it disconnects, it will not reconnect...even if I reset or power off the board. The only way it will reconnect is if I reload the INO on the board. Tried v.118 with the same problem.
I decided maybe it was the boards so I broke down and purchased a genuine UNO with a v2 Ethernet Shield, updated the ino to v2 shield through the plugin interface, updated the libraries and loaded the ino. Plugin connected and has been up for 4 days and running.
So if anyone is still having issues with connections it might be worth trying genuine Arduino products if all as fails.
