1.0.0.118 installed here. All boards connected immediately.
4X Mega 2560 boards, all with Ethernet shields (1st gen POE).
aug-10 18:14:18 Arduino Plugin Disconnected from Board No:1 at ip address 192.168.0.91 Port No:8888 aug-10 18:14:18 Arduino Plugin Error = Board: 1 Connection FAILED. aug-10 18:14:02 Arduino Plugin Warning = Board: 1 has a connection ERROR. Retrying. aug-10 18:13:52 Arduino Plugin Warning = Board: 1 has a connection ERROR. Retrying. aug-10 18:12:47 Arduino Plugin New Com port Found aug-10 18:12:46 Arduino Plugin Updating Values on Board No: 1 aug-10 18:12:45 Arduino Plugin Updating pins on Board No: 1 aug-10 18:12:45 Arduino Plugin Connected to Board No:1 at ip address 192.168.0.91 Port No:8888 aug-10 18:12:44 Plug-In Finished initializing plug-in Arduino Plugin aug-10 18:12:44 Arduino Plugin Plug-in initialized. aug-10 18:12:44 Arduino Plugin Connecting Board No:1 at ip address 192.168.0.91 Port No:8888 aug-10 18:12:44 Arduino Plugin Auto Connecting Board No:1 aug-10 18:12:43 Arduino Plugin Checking boards config aug-10 18:12:41 Info Plugin Arduino Plugin has connected. IP:127.0.0.1:65522
