Arduino Plugin Error = Exception in UDPGetMessage
  • Arduino Plugin Error = Exception in UDPGetMessage
    HI,
    Since some time now I get the error message in the log:
    'Arduino Plugin Error = Exception in UDPGetMessage : Operation on non-blocking socket would block'
    Can anyone give me a clue where to look for the solution of this problem. Is it something in the sketch? I am reading the data from a Cozir CO2 sensor and sending that to HS.
    My whole code looks like:
    void setup() {
    HSSetup();
    Serial.begin(9600);
    //Startup Cozir Sensor
    czr.SetOperatingMode(CZR_POLLING);
    czr.SetDigiFilter(64);
    void loop() {
    #if ISIP == 1
    IsUDP();
    #endif
    // wait interval1
    unsigned long currentMillis = millis();
    if (currentMillis - previousMillis >= interval1) {
    previousMillis = currentMillis;
    //read sensor
    cotwo = czr.CO2();
    t = czr.Celsius();
    h = czr.Humidity();
    SendToHS(1, cotwo);
    SendToHS(2, t);
    SendToHS(3, h);
    /*Execute regardless of connection status*/
    if (IsConnected == true) {
    /*Execute ONLY when HomeSeer is connected*/
    About the parameters: t and h are float and cotwo is int.
    thanks in advance!
    Cor
    This is a strange one. What version of the plugin are you using?
    Greig.
    Zwave = Z-Stick, 3xHSM100 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
    Scripts =
    Various
      I am using Version 1.0.0.115
      Cor
        Greig,
        Just to inform you, I switched recently to a Raspberry Pi 3. Now I am using mono 4 instead of mono 3. The number of this error messages has drasticly reduced!
        Is there a specific version of mono that can be used best?
        -Cor-
