1wire device version
  • 1wire device version
    Any idea what causes these errors? It reads the device, but seems it's missing the version (NO_VERSION)?
    I'm assuming it's the 1wire devices I use (DS1920) are not supported (They're pretty ancient)
    Z
    Jul-21 11:24:18 AM Arduino Plugin Error = Exception in RecievedRom : There is not a method with name 'GetType' in service class. Service Version: NO_VERSION
    Jul-21 11:24:18 AM Arduino Plugin Rom Address = 2410906F24043BA , Value = 29.69
    Jul-21 11:24:18 AM Arduino Plugin Data Received:1 Rom 162420987000800186 29.69
    Jul-21 11:24:17 AM Arduino Plugin Error = Exception in RecievedRom : There is not a method with name 'GetType' in service class. Service Version: NO_VERSION
    Jul-21 11:24:17 AM Arduino Plugin Rom Address = 2410906F24043BA , Value = 29.75
    Jul-21 11:24:17 AM Arduino Plugin Data Received:1 Rom 162420987000800186 29.75
    Z
    The supported devices are DS18S20, DS18B20 or DS1822 but this may work. Can you get the standard one wire sketch to see them? Send me a debug and I will see what is being sent.
    Greig.
    Zwave = Z-Stick, 3xHSM100 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
    Scripts =
    Various
      Greig.
      Odd thing is, it worked prior to .115 and it works on the example script.
      Other odd thing, is when I have the devices connected, the digital inputs stop responding.. Like it's stuck in a OneWire discovery loop..
      I've disconnected it waiting for new 3wire devices, so don't have a debug right now. Should have the parts tomorrow so have an update soon.
      Z
        OK, still getting the same error (Debug log below). I'm running Dallas Lib 3.7.6 and OneWire Lib 2.3.2. New DS18B20, no other devices connect.
        All Dallas and OneWire example sketches work fine and identify the device (The PI does as well, it just doesn't like something) Looks like the PI is either not finding what it's looking for, or not accepting new data sent to it (VERSION). I wonder if this only occurs on new devices added which would explain why existing systems still work OK?
        Z
        22/7/2016 ,13:43:19.725 Data Received:1 Rom 4014091040000128238 29.50
        22/7/2016 ,13:43:19.726 Timer 1 Reset
        22/7/2016 ,13:43:19.732 Rom Address = 37B4EA88874934EE , Value = 29.50
        22/7/2016 ,13:43:19.739 Exception in RecievedRom : There is not a method with name 'GetType' in service class.
        22/7/2016 ,13:43:27.236 Data Received:1 Rom 4014091040000128238 29.00
        22/7/2016 ,13:43:27.237 Timer 1 Reset
        22/7/2016 ,13:43:27.239 Rom Address = 37B4EA88874934EE , Value = 29.00
        22/7/2016 ,13:43:27.243 Exception in RecievedRom : There is not a method with name 'GetType' in service class.
        22/7/2016 ,13:43:57.619 Sent to com port No:10 = 1 K ,Keep Alive Command
        22/7/2016 ,13:43:57.620 Keeping Board: 1 Comport Alive.
        22/7/2016 ,13:43:57.792 Data Received:Alive 1
        22/7/2016 ,13:44:27.331 Data Received:1 Rom 4014091040000128238 29.00
        22/7/2016 ,13:44:27.332 Timer 1 Reset
        22/7/2016 ,13:44:27.336 Rom Address = 37B4EA88874934EE , Value = 29.00
        22/7/2016 ,13:44:27.339 Exception in RecievedRom : There is not a method with name 'GetType' in service class.
          Looks like it's failing at RecievedRom.
          If flagArray(0) Then
          Util.hs =
          DirectCast(Conversions.ChangeType(RuntimeHelpers.GetObjectVa lue(objArray(0)),
          GetType(IHSApplication)), IHSApplication)
          End If
          Z
            can you send me a debug of this so I can have a better idea of what is causing it.
            Greig.
            Scripts =
            Various
              Greig.
              Here you go.
              THanks,
              Z
                Thanks.
                I can now reproduce the error so will hunt it down and get it fixed. I am at work for the next 2 days so give me time.
                Greig.
                Scripts =
                Various
                  Thanks.
                  Greig.
                  Not a problem, I can live without the temps for awhile.
                  Z
                    OK I found enough time at lunch to get this fixed. Please try V.116 in the beta section of the updater.
                    Greig.
                    Scripts =
                    Various
                      Greig.
                      Can't download the sketch.
                      At PI startup it gives on the PI page:
                      API Version = Error Finding API.ino
                      When you try to download the sketch it gives:
                      Error Creating Homeseer.ino = (Error finding line = #define BoardType)
                      I see the dropdown for the board type is now: Arduino and Ardunio API
                      Z
                        Should have added that it does fix the problem with OneWire though.
                        Z
                          Sorry about that. It should be fixed in V.117
                          Greig
                          Scripts =
                          Various
                            Greig
                            Perfect...
                            Z
