Linux Arduino Plugin Error
  • Linux Arduino Plugin Error
    Hello.
    I want to test the Linux HS3 and Arduino Plugin and i have this error in the Arduino IDE :
    /home/linux/Scaricati/HomeseerBoard1/HomeseerBoard1.ino:19:17: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
    char* Version = "1.0.0.111";
    /home/linux/Scaricati/HomeseerBoard1/HomeseerBoard1.ino: In function 'void InputCheck()':
    /home/linux/Scaricati/HomeseerBoard1/HomeseerBoard1.ino:98:17: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
    Send(" I ");
    /home/linux/Scaricati/HomeseerBoard1/HomeseerBoard1.ino:100:15: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
    Send(" ");
    /home/linux/Scaricati/HomeseerBoard1/HomeseerBoard1.ino: In function 'void AnalogueCheck()':
    /home/linux/Scaricati/HomeseerBoard1/HomeseerBoard1.ino:172:19: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
    Send(" A ");
    /home/linux/Scaricati/HomeseerBoard1/HomeseerBoard1.ino:174:17: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
    Send(" ");
    /home/linux/Scaricati/HomeseerBoard1/HomeseerBoard1.ino: In function 'void OneWireCheck()':
    /home/linux/Scaricati/HomeseerBoard1/HomeseerBoard1.ino:238:21: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
    Send(" Rom ");
    /home/linux/Scaricati/HomeseerBoard1/HomeseerBoard1.ino:241:50: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
    if (tempDeviceAddress[i] < 16) Send("0");
    /home/linux/Scaricati/HomeseerBoard1/HomeseerBoard1.ino:244:17: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
    Send(" ");
    /home/linux/Scaricati/HomeseerBoard1/HomeseerBoard1.ino: In function 'void DataEvent()':
    /home/linux/Scaricati/HomeseerBoard1/HomeseerBoard1.ino:472:21: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
    Send(" I ");
    /home/linux/Scaricati/HomeseerBoard1/HomeseerBoard1.ino:474:19: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
    Send(" ");
    /home/linux/Scaricati/HomeseerBoard1/HomeseerBoard1.ino:483:24: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
    Send("Version ");
    /home/linux/Scaricati/HomeseerBoard1/HomeseerBoard1.ino:485:17: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
    Send(" ");
    /home/linux/Scaricati/HomeseerBoard1/HomeseerBoard1.ino:487:20: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
    Send(" HS3");
    /home/linux/Scaricati/HomeseerBoard1/HomeseerBoard1.ino:490:26: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
    Send("Connected ");
    /home/linux/Scaricati/HomeseerBoard1/HomeseerBoard1.ino:651:22: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
    Send("Alive ");
    /home/linux/Scaricati/HomeseerBoard1/HomeseerBoard1.ino:677:25: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
    Send("Reseting ");
    I need your help.
    Marian
    Please try V.118 and see if that helps you.
    Greig.
    Scripts =
    Various
      Sorry Greig, but for me is an problem with Arduino Plugin because i test to upload the skretch to arduino board but .... i have the error with Arduino IDE 1.6.8
      This is Error :
      " Build options changed, rebuilding all
      C:\Users\Marian\Documents\HomeseerBoard1\HomeseerBoard1.ino: 19:17: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
      char* Version = "1.0.0.118";
      C:\Users\Marian\Documents\HomeseerBoard1\HomeseerBoard1.ino: In function 'void InputCheck()':
      C:\Users\Marian\Documents\HomeseerBoard1\HomeseerBoard1.ino: 98:17: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
      Send(" I ");
      C:\Users\Marian\Documents\HomeseerBoard1\HomeseerBoard1.ino: 100:15: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
      Send(" ");
      C:\Users\Marian\Documents\HomeseerBoard1\HomeseerBoard1.ino: In function 'void AnalogueCheck()':
      C:\Users\Marian\Documents\HomeseerBoard1\HomeseerBoard1.ino: 172:19: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
      Send(" A ");
      C:\Users\Marian\Documents\HomeseerBoard1\HomeseerBoard1.ino: 174:17: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
      Send(" ");
      C:\Users\Marian\Documents\HomeseerBoard1\HomeseerBoard1.ino: In function 'void OneWireCheck()':
      C:\Users\Marian\Documents\HomeseerBoard1\HomeseerBoard1.ino: 238:21: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
      Send(" Rom ");
      C:\Users\Marian\Documents\HomeseerBoard1\HomeseerBoard1.ino: 241:50: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
      C:\Users\Marian\Documents\HomeseerBoard1\HomeseerBoard1.ino: 244:17: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
      Send(" ");
      C:\Users\Marian\Documents\HomeseerBoard1\HomeseerBoard1.ino: In function 'void DataEvent()':
      C:\Users\Marian\Documents\HomeseerBoard1\HomeseerBoard1.ino: 472:21: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
      Send(" I ");
      C:\Users\Marian\Documents\HomeseerBoard1\HomeseerBoard1.ino: 474:19: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
      Send(" ");
      C:\Users\Marian\Documents\HomeseerBoard1\HomeseerBoard1.ino: 483:24: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
      Send("Version ");
      C:\Users\Marian\Documents\HomeseerBoard1\HomeseerBoard1.ino: 485:17: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
      Send(" ");
      C:\Users\Marian\Documents\HomeseerBoard1\HomeseerBoard1.ino: 487:20: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
      Send(" HS3");
      C:\Users\Marian\Documents\HomeseerBoard1\HomeseerBoard1.ino: 490:26: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
      Send("Connected ");
      C:\Users\Marian\Documents\HomeseerBoard1\HomeseerBoard1.ino: 651:22: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
      Send("Alive ");
      C:\Users\Marian\Documents\HomeseerBoard1\HomeseerBoard1.ino: 677:25: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
      Send("Reseting ");
      Sketch uses 24,536 bytes (9%) of program storage space. Maximum is 253,952 bytes.
      Global variables use 2,097 bytes (25%) of dynamic memory, leaving 6,095 bytes for local variables. Maximum is 8,192 bytes.
      I tryed with Linux Arduino IDE and with Windows Arduino IDE and i have the same error.
      You're sure it's not a problem by Arduino Plugin for Linux?
      Marian
        I downloaded the libraries from Arduino Plugin Page and is the same error.
          This should not stop it working as it is just a warning about a change in the ide but the board should still upload the sketch and work.
          Greig.
          Scripts =
          Various
