System standby?
  • System standby?
    Hello to all.
    First ,sorry for my english.
    I have an system HS3 with 6 arduino mega 2560 and 2 arduino one from 2 yers ago.
    1 week ago, i am updated the system to .293 and the Arduino plugin to .118 versions.
    Now i have this problems :
    1. for all the arduino boards i have the deelay with the first command.
    For example : for baord 1 - if i have the command for any input pin - the board work perfect. but if i don't have any command for 2-3 hours the arduino board it seems in standby and for first command i have the deelay (5-10 sec.). From second work fine but if i have another pause of the commands - after is the same delay.
    2.In the Arduino Plugin Page if change the name of state to Output (by default is OFF and ON - i changed with UP and Down) after reboot af the system the name is OFF and ON (isn't the UP and Down).
    I need your help specialy for the "standby" problem.
    Thank you,
    Marian
    Try V.123 this should fix it for you.
    Greig.
    Zwave = Z-Stick, 3xHSM100 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
    Scripts =
    Various
      Ok.Thanks. Now is all ok
