Hi Greig
Just testing the USB side of the house. I note when I unplug a board that the comm port disappears. Appears that the plugin tries to reconnect a few times and then stops.
When I plug my board back in it wont connect unless I click the connect button. This is also with the autoconnect box checked. Not sure if that does anything for USB ?
Sep-24 00:29:12 Arduino Plugin Error = Exception in Disconnect close port : The specified port does not exist.
Sep-24 00:29:12 Arduino Plugin Error = Exception in SendToPort : The port 'COM13' does not exist.
I can add an event every minute to reconnect if the board shows failed however thats not as elegant as I'd hoped :-) Does it make sense to close the port and stop trying ?
Your thoughts ?
Pete
Your thoughts ?
Pete
