1Wire Exception in ReceivedRom Value
  • 1Wire Exception in ReceivedRom Value
    Hi
    I have been seeing the following errors ever since I updated from V1.0.0.36
    Arduino Plugin Error = Exception in RecievedRom Value > -100 And Value < 150 : Conversion from string "4025505011002102161, value Error" to type 'Long' is not valid.
    Arduino Plugin Error = Rom = Parents Thermostat has an error
    Any ideas?
    I am running V1.0.0.124
    GLW
    This is the onewire rom not updating in time.
    Greig.
    Zwave = Z-Stick, 3xHSM100 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
    Scripts =
    Various
      Hi Greig,
      I connected a new DS18B20 and I am still seeing this error.
      I also see that another user (GPrade) has opened a thread "Occasional errors with DS18B20" with the same issues I am having.
      GLW
        This is just a timeout to say the rom has not updated within a given time. I maybe next to make this time user adjustable.
        Greig.
        Sent from my SM-G925F using Tapatalk
        Scripts =
        Various
          Greig.
          That would be a nice improvement. It would likely help stop the errors that Gary noted in his post. I have been using a 3.3k pull-up instead of 4.7k on all four of my boards, which seems to have stopped the errors.
          Randy Prade
          Aurora, CO
          Prades.net
            Greig.
            If you need more incentive , I've seen the plugin crash due to it's not being able to crunch the text ID into an integer (too long).
            Z
            From HS3 Log:
            Oct-31 12:52:35 PM Info Plugin Arduino Plugin has connected. IP:127.0.0.1:51652
            Oct-31 12:52:35 PM Warning I/O interface Arduino Plugin is down, executable is not running, restarting ...
            Oct-31 12:52:28 PM Error Calling HSEvent in plugin Arduino Plugin, Instance :Object reference not set to an instance of an object.
            Oct-31 12:52:28 PM Info Plugin Arduino Plugin with instance: has disconnected
            Oct-31 12:52:23 PM Z-Wave Device: Temperatures Shelter Front Door Temperature Set to 73.3 (F)
            Oct-31 12:48:23 PM Z-Wave Device: Temperatures Shelter Front Door Temperature Set to 73.2 (F)
            Oct-31 12:37:22 PM Arduino Plugin Error = Exception in RecievedRom Value > -100 And Value < 150 : Conversion from string "4014091040000128238, value Error" to type 'Long' is not valid.
            From HS3 Server Event log:
            Log Name: Application
            Source: .NET Runtime
            Date: 10/31/2016 12:52:23 PM
            Event ID: 1026
            Task Category: None
            Level: Error
            Keywords: Classic
            User: N/A
            Computer: SHELTERMONITOR2
            Description:
            Application: HSPI_Arduino.exe
            Framework Version: v4.0.30319
            Description: The process was terminated due to an unhandled exception.
            Exception Info: System.InvalidCastException
            Stack:
            at Microsoft.VisualBasic.CompilerServices.Conversions.ToLong(Sy stem.String)
            at Microsoft.VisualBasic.Conversion.Hex(System.Object)
            at HSPI_Arduino.Util.RecievedRom(System.String[])
            at HSPI_Arduino.Util+_Closure$__._Lambda$__R94-8(System.Object)
            at System.Threading.ThreadHelper.ThreadStart_Context(System.Obj ect)
            at System.Threading.ExecutionContext.RunInternal(System.Threadi ng.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
            at System.Threading.ExecutionContext.Run(System.Threading.Execu tionContext, System.Threading.ContextCallback, System.Object, Boolean)
            at System.Threading.ExecutionContext.Run(System.Threading.Execu tionContext, System.Threading.ContextCallback, System.Object)
            at System.Threading.ThreadHelper.ThreadStart(System.Object)
            Event Xml:
            <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
            <System>
            <Provider Name=".NET Runtime" />
            <EventID Qualifiers="0">1026</EventID>
            <Level>2</Level>
            <Task>0</Task>
            <Keywords>0x80000000000000</Keywords>
            <TimeCreated SystemTime="2016-10-31T16:52:23.000000000Z" />
            <EventRecordID>70137</EventRecordID>
            <Channel>Application</Channel>
            <Computer>SHELTERMONITOR2</Computer>
            <Security />
            </System>
            <EventData>
            <Data>Application: HSPI_Arduino.exe
            Stack:
            </Data>
            </EventData>
            </Event>
              Try beta 1.0.0.131. Greig made the changes. There is a change in the way the plug-in evaluates if the device is updating as well as an error timeout parameter that defaults at 2 seconds. One of the two changes may stop your errors.
              Randy Prade
              Aurora, CO
              Prades.net
                I'll do that, I'm sure it will help.
                I was primarily letting him know that he has an Exception that he's not handling in his code that terminates his plugin.
                Z
                  Yep that's what was fixed.
                  Greig
                  Scripts =
                  Various
                    Greig
                    Great, I'll try it out tonight.
                    Z
