Hi I have a Funduino Mega 2560 with 16 ch relay board.
I have some issue's that I can not find out how to resolve.
1, When I assign a pin as a output the relay defaults to on when the device in HS3 is off, and if you turn the device on it turns the relay off.
2, Unstable input pins. I get pins firing events when out puts are been switched.
for example If i latch relay 1 it may also trigger Input 6 (smoke sensors)
I've tried adding pull up resisters but does not seem to make any difference.
I was wondering if I should have a separate Board in another box for handling inputs, This would keep them separate from the out put I/O box.
or is the problem the brand of MEGA 2560 (Funduino)
3, Blink and One flash functions don't work?
Current Date/Time: 16/10/2016 8:50:03 PM
HomeSeer Version: HS3 Standard Edition 3.0.0.297
System Uptime: 0 Days 2 Hours 34 Minutes 0 Seconds
IP Address: 192.168.20.5
Number of Devices: 75
Number of Events: 84
Available Threads: 200
Enabled Plug-Ins
1.0.0.127: Arduino Plugin
3.0.20.13608: Blue-Iris
3.0.0.68: HSTouch Server
3.0.5.20: Insteon
0.0.0.25: Pushover 3P
3.0.6132.26687: UltraLighting3
Enabled Plug-Ins
3.0.5.20: Insteon
