blink and flash
  • blink and flash
    On the guide i read:
    Output: Outputs can be controlled in the following way:
    On: Turns the output High
    Off: Turns the output Low
    Blink: This will Blink the output on and off at the time set by the Output Time device for the given pin
    One Flash: This will Set the Output High then Low using the time set by the Output Time device for the
    given pin
    But where I can set "the Output Time device for the given pin"?
    There should be a device for each output time. If you dont see them then check your device type filter. See screenshot below.
    Greig.
    Zwave = Z-Stick, 3xHSM100 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
    Scripts =
    Various
      Greig.
      Thanks Greig, filter was my problem! (I tried the solution into "arduino plugin config")
