How would I create a single button momentary toggle dimmer switch exactly like how the Fibaro, Aeotec and DHS dimmers all work. Used to push once to turn it off and on and hold down to dim. No z wave dimmers work in my instance. (ripple tone issue among other harmonics I have been told, also dimming range is appauling)
I then need to link this dimming function to a PWM output.
I currently have 14 down lights I can control from HS Touch or the HS control panel like a charm with 0% to 100% full dimming range at 20-24 volts with PWM. (works flawlessly and much better range than z wave dimmers have)
The only thing holding me back from doing more rooms is that I have no way of controlling the lights from a wall switch.
I can run wires anywhere if needed. Thanks for any help given.
