attachInterrupt()
  • attachInterrupt()
    Hi Greig,
    do you think is it possible to use the attachinterrupt() in API sketch?
    I'm using an API sketch to calculate the duration between 2 pulse (1 pulse every 1W).
    In the same sketch I added 2 onewire DS18B20 sensor. I'm having delay on pulse reading duration because DS18B20 needs 750ms to elaborate the temperature.
    My idea is to use attachinterrupt() to calculate the duration between pulse.
    /////PULSE CONSUMI////START
    unsigned long tempo_trascorso = millis();
    void setup(){
           attachInterrupt(0,calcola_tempo,FALLING);
    void calcola_tempo(){
       duration=millis()-tempo_trascorso;
       tempo_trascorso=millis();
    power = 3600.0 / duration * 1000;
    Do you think the interrupt could cause problem in API sketch?
    Yes, it is possible!
