Wireless Connection
  • Wireless Connection
    Based on the comments I saw, it seems I need a wire connection (USB/Ethernet/Serial). However, I don't have any of those options. Can I get this to work wirelessly? If so, is there a particular Arduino shield I should use? If Arduino does not support it, then does RaspberryPi?
    At the moment there is no wireless support in the plugin. You can use serial to wireless adaptors on your board and server to get this to work and I have started to ad support for other boards that have wireless built in but I am having problems with this.
    Greig.
    Zwave = Z-Stick, 3xHSM100 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
    Scripts =
    Various
      FYI there is now support for the NodeMCU board in the Beta plugin which connect with WiFi.
      Grieg.
      Scripts =
      Various
        Grieg.
        Grieg, just wanted to say how much I (and I'm sure everyone else) appreciate the effort you put into this plugin. When I have time I'm definitely going to play with some NodeMCU boards!
