X10 PUM01 Universal Module/Receiver
  • bbowser
    Originally posted by ffarrell View Post
    I forgot I have a Adicon 2500 I/O that should work with the GTS CPUXA Ocelot Plug-in.
    do you think this will work? I'm just looking for status of door open or door closed.
    I have one door that has a door jam switch. I also have a door with contacts. any ideas would be great.
    thanks
    fvf
    Yes, if you have a Secu16 (8 Inputs and 8 Outputs) or a Secu16i (16 Inputs) that will work with the plugin
    Bruce
  • ffarrell
    thanks
    fvf
  • langenet
    Yes, you need a Powerflash module to receive the contact closure signal and send it to HS3. Then your event can have "IF the X10 system executed the Device On command on "
    Robert
  • bbowser
    ffarrell,
    After looking at the X10 PUM01 Universal Module/Receiver a little closer, that unit looks like a low voltage relay device, similar to an appliance module but a contact closure that can't handle a lot of voltage or current. It's like an X10 version of a Global Cache IP2CC-P.
    If you want to monitor door contacts using x10 you may need an X10 PF284 or PSC01 X10 Powerflash Interface. I am not an X10 expert but if the PF284 or PSC01 sends an X10 On and OFF out like the X10 motion sensors do. They will work with the plugin.
    Bruce
  • bbowser
    I have door contacts that I would love to add into my new HS3. is it possible to add X10 PUM01 Universal Module/Receiver support for monitoring status?
    thanks
    fvf
    ffarrell,
    Have you tried using an appliance module device? I don't have one to test but it looks like they respond to X10 ON and OFF commands. In that case they should work as an appliance module.
    Giver a try and let me know
    Bruce
  • Rupp
    You need a supported X10 interface like the TI-103, CM11A, or the CM15A. There are a couple of other interfaces that are supported as well. If memory serves me the X10 PUM01 was used in conjunction with an Ocelot unit to talk X10 a few years back.
  • ffarrell
    started a topic X10 PUM01 Universal Module/Receiver
    thanks
    fvf
