Testing plugin in Linux
    Great plugin. Not sure if anyone is using it in Linux today.
    Testing it in Ubuntu 16.04 64 bit and noticed that it it writing to the root drive.
    HS3 Pro Edition 3.0.0.291 (Linux)
    GTS CPUXA 3.5.16105.96
    What it writes to the root drive.
    HomeSeer\Debug Logs\Ocelot.log
    HomeSeer\Debug Logs
    Note here keep HomeSeer in the root drive /HomeSeer
    Plugin should write:
    /HomeSeer/Logs/Debug/Ocelot.log
    or just
    /HomeSeer/Logs/Ocelot.log
    Over time it starts to error with RW errors to the above mentioned errors.
    - Pete
    Auto mator
    HS4 Pro - V4.1.11.0 - Ubuntu 20.01/VB W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono
    6.10.0.104
    HS4 Lite -
    HomeSeer\Debug Logs
    or just
    Pete,
    Thanks for the report. I tested the plugin in Debian 7 and Centos 7, I will take a look at it when I get back on Monday.
    Bruce
