variable scripting
  • variable scripting
    I am not able to change any variables through script, I can however change them through an event. I can set outputs through script and events. I would like to be able to change a variable through a script as that would reduce the number of events needed for multiple values.
    Hi srector,
    I just tested the variable scripting and it's working if you follow the examples in the online help.
    Below is what I just tried:
    Sub Main(Parm As Object)
        ' get a reference to the plugin
    Dim plugin = New HomeSeerAPI.PluginAccess(hs, "GTS CPUXA", "")
    Dim arr(1) As Object
    arr(0) = 397 ' Device Ref Number
    arr(1) = 60 ' Device value (For relays 1 = on / 0 = off) (For vars 0 thru 65535)
    ' call the function and set the value
    plugin.PluginFunction("CPUXA_Set", arr)
    End Sub
    Let me know if you continue to have issues, we'll get through it
    Bruce
      I can change an output via that script but not a variable. also I am unable to start, stop or change a timer via scripting
        srector,
        I'll PM you and we can try some things.
        Bruce
