Hello Bruce,
I have an SECU16IR connected to my Leopard 1 unit that is connected and set up. The leopard was connected to a different computer than my Hometroller S6 Pro when it was set up and the IR trained. Apparantly the IR codes are still saved in leopard 1. First of all, is this correct?
I went to the configuration page for IR and it shows bank 0-10. Not sure what this means (maybe secu16 units 1-16 I assume)? I have one secu16 so selected bank 0. Underneath the banks it shows Ocelot U0 and Secu16IR U4. I selected Secu16IR U4. Then it shows 16 zones (0-15). I have IR outputs connected to zones 6 and 7. When I select the zones there are check boxes for IR0-IR99.
ON the leopard the codes were saved like this:
MBStereo,TV on
MBStereo,TV off, etc.
Can I still use these names or do I need to select and check for instance IR0 Box and retrain the IR Code to IR0,etc. and these IR0-IR99 selections would be the new IR names used by HS3 events. Also I assume there are 100 codes for each zone? Also again do I need to retrain over again or not with your plugin in HS3? Looking forward to your reply !!!! Rick
MBStereo,TV on
