I/O Page Blank In Config Screen, Etc.
  • Rick Bonari
    Restarting homeseer software resolved the issue. Thanks much !!!! Rick
  • bbowser
    Rick,
    I assumed you tried restarting HS3, yes try that. The ini is in the HS3/config dir.
    Bruce
  • Rick Bonari
    Hi Bruce,
    Should I try closing homeseer software and then reopen it? Maybe this will clear it? Will try when I get home.
    Where would I find the .ini file?
    Thanks much......Rick
  • bbowser
    Rick,
    That is very strange, haven't had any reports of anything like that happening. Maybe the Ocelot/Leopard didn't initialize correctly on startup or the hspi_gts_cpuxa.ini is corrupt? You can email the hspi_gts_cpuxa.ini and I'll take a look at it.
    Bruce
  • Rick Bonari
    started a topic I/O Page Blank In Config Screen, Etc.
    Hello Bruce,
    I noticed in device management screen that variable 10 showed 65536 for the one humidity bobcat device I have connected. I only have one bobcat device. It appears to be working fine and reporting humidity value correctly. Usually the variable value is same as humidity value. I went to configuration page and in the main page it said I have 11 adnet devices. All 11 were bobcat units. I only have the one? Wow what is up with that? Also I went to the I/O page and it is blank like nothing showing. My I/O seems to be working fine. Not sure what is up with plugin? Your help on this is much appreciated..Rick
    Last edited by Rick Bonari; April 29, 2018, 10:09 PM. Reason: Additional Information
