Stuart,
That is not an error, it's a leftover test that I was experimenting with back in 2015 when I wrote the plugin. That log message was only supposed to happen when the "Log Communications to Ocelot.log" checkbox was checked and the plugin got a notification that an input changed. I remember commenting the "if" out because the Ocelot was not sending the IO change notification reliably. I ended up doing something different and never removed the commented "if". So... you can ignore it or send me a PM and I'll fix you up :-)
Bruce
IO DEBUG
IO DEBUG
What should I be looking at when getting these errors
Stuart
Feb-18 6:08:59 PM IO DEBUG Input change detected Feb-18 6:00:13 PM IO DEBUG Input change detected Feb-18 5:14:42 PM IO DEBUG Input change detected Feb-18 4:57:42 PM IO DEBUG Input change detected Feb-18 4:57:13 PM IO DEBUG Input change detected Feb-18 4:54:20 PM IO DEBUG Input change detected Feb-18 4:16:40 PM IO DEBUG Input change detected Feb-18 4:13:13 PM IO DEBUG Input change detected Tags: None
