I am checking out the HS3 Ocelot plugin for Linux before I buy it and I cannot learn a Dish remote that uses 56K freq for IR when using the HS3 plugin. When I do the steps to learn the IR code from the remote using the plugin I am told they are learned but they do not work. If I use CMAX and choose the 56K option for the IR freq the Ocelot learns the code and can then send the code using the HS3 plugin. I noticed that the HS3 plugin does not ask for the IR freq so I suspect it is defaulting to 38K and cannot really learn remotes with 56K ir freq. If possible can the HS3 plugin be updated to handle both 38K and 56K freq? Thanks
Possible Problem with latest HS3 Ocelot Plugin with learning 56K IR devices
