Quick Update
  • bbowser
    Originally posted by martin View Post
    Bruce, thanks so much for doing this. It really helped deal with an otherwise ugly Adicon problem.
    One small beg: my log is getting jammed with trivial bobcat updates. Any chance of an option to disable Bobcat updates, or maybe have them only happen when the temperature changes only to the left of the decimal point?
    Hi Martin,
    Do you have the "Do not log commands from this device:" in the device configuration checked? I don't have my Ocelot testing station setup to test if this is working at the moment. If this does not work for you let me know and I will fix it.
    Bruce
  • Guest's Avatar
    Guest replied
    Bobcat logging - small beg
  • bbowser
    Originally posted by Roby View Post
    Yes, I have 10 Secu16, 1 Secu16IR, 1 Speak EZ, 1 XM10, and I use all of the I/O.
    Roberto
    Roberto,
    It's on the list, I will give you an idea of timing in the next few days.
    Bruce
  • Roby
    Originally posted by bbowser View Post
    Hello Roby,
    The plugin supports 6 units now, are you saying you have 11 units total? That's a lot of IO
    It is possible... If you indeed have 11 units I will schedule the time to double what the plugin currently supports. If there are others out there with more than 6 units that may be interested in the plugin, let me know what you need
    Bruce
    Roberto
  • bbowser
    Hello Roby,
    Bruce
  • Roby
  • bbowser
    started a topic Quick Update
    Quick Update
    Some performance issues were detected and rectified. Beta testers are reporting a marked improvement. An update will be posted this week of 3/21/16.
    After this update, X10 will be gone through in greater detail. We will attempt to incorporate all Ocelot X10 capability in the plugin.
