Output on/off and status issues
  • mega
    it's work with need version. Status to thank you
  • spud
    I think this is a bug introduced in version 3.0.0.8, I fixed it in version 3.0.0.9.
    Please test this version and let me know. Thanks!
  • mega
    debug mode log
    RaspberryIO DEBUG Pin13 value changed to Off
    RaspberryIO DEBUG Setting direction to Output for Pin13
    RaspberryIO DEBUG Setting direction to "Not Used" for Pin13
    RaspberryIO DEBUG Pin27 value changed to On
    RaspberryIO DEBUG Pin27 value changed to Off
    RaspberryIO DEBUG Pulsing Pin27 for 1000ms
    Device Control Device: RAS RaspberryIO GPIO 27 to Pulse (-1001) by/from: CAPI Control Handler
    RaspberryIO DEBUG Pin22 value changed to Off
    RaspberryIO DEBUG Setting Pin22 to Off
    RaspberryIO DEBUG Pin22 value changed to On
    RaspberryIO DEBUG Toggling Pin22
    when : RaspberryIO DEBUG Setting direction to Output for Pin13
    Put led on,
    when i choose not used : RaspberryIO DEBUG Pin13 value changed to Off
    and put led off
  • spud
    it doesn't look like you set the log level to Debug...
    also you don't need to start the RaspberryIO plugin instance on your HS3 server.
    set the log level to Debug for the remote instance, then stop the plugin on your HS3 server as well as the remote instance, then delete all your RaspberryIO HS devices, then restart the remote instance only (i.e. sudo ./run.sh)
  • mega
    Log
    Raspberry Pi 3B
    HS (Inverse log) :
    Device Control Device: RAS RaspberryIO GPIO 5 to On (1) by/from: CAPI Control Handler
    Device Control Device: RAS RaspberryIO GPIO 5 to Off (0) by/from: CAPI Control Handler
    Device Control Device: RAS RaspberryIO GPIO 27 to On (1) by/from: CAPI Control Handler
    Device Control Device: RAS RaspberryIO GPIO 17 to On (1) by/from: CAPI Control Handler
    Device Control Device: RAS RaspberryIO GPIO 17 to Off (0) by/from: CAPI Control Handler
    Device Control Device: RAS RaspberryIO GPIO 27 to Off (0) by/from: CAPI Control Handler
    RaspberryIO INFO Serial number:
    RaspberryIO INFO Firmware rev10494082, board model B3 (Raspberry Pi 3 Model B)
    RaspberryIO INFO Raspberry Pi running on Bcm2835 processor
    RaspberryIO INFO RaspberryIO version 3.0.0.8
    Info Plugin RaspberryIO with instance RAS has connected. IP:192.168.1.154:36628
    RaspberryIO ERROR System is not a Raspberry Pi
    Plug-In Finished initializing plug-in RaspberryIO
    Info Plugin RaspberryIO has connected. IP:127.0.0.1:61705
    On PI :
    pi@raspberrypi:~/RaspberryIO $ sudo ./run.sh
    Plugin: RaspberryIO Instance: RAS starting...
    Connecting to server at 192.168.1.15...
    Connection attempt #1
    Connected (HomeSeer API 3). Waiting to be initialized...
    INFO Serial number:
    No errors in log (debug). Status change in homeseer, led does not toogle. Led work with other web interface and ssh. Ideas ? Sorry for my english.
  • spud
    What model of RPi are you testing?
    Could you try to connect a simple LED to the GPIO you are testing.
    Do you run the plug-in as a remote instance? If so do you use sudo to start it?
    Could you set the log level to debug, then restart the plug-in, and post your logs. Thanks
  • mega
    started a topic Output on/off and status issues
    When I put to output, gpio received command. When I try to on /off not work, same with status.
    Ssh gpio work great.
    Good mono version installed
    Help please
