ERROR System is not a Raspberry Pi
  • ERROR System is not a Raspberry Pi
    Just picked up a Raspberry Pi 3 B+ and am attempting to install RaspberryIO as a remote plugin to my current Homeseer setup. I'm running HS3 Pro Edition 3.0.0.425 on Windows 10. I followed the install guide and when I launch the plugin I get an error in both Homeseer and on the Pi that states "ERROR System is not a Raspberry Pi".
    Output from Pi:
    admin@raspberrypi:/opt/RaspberryIO $ sudo ./run.sh
    Plugin: RaspberryIO Instance: doors starting...
    Connecting to server at 192.168.0.99...
    Connection attempt #1
    Connected (HomeSeer API 3). Waiting to be initialized...
    Oct-07 11:06:50 INFO RaspberryIO version 3.0.0.12
    Oct-07 11:06:56 ERROR System is not a Raspberry Pi
    Logs from Homeseer (it just repeats this over and over). I do have the log level output set to Debug and this is all it reported which seemed odd?
    Oct-07 11:54:04 AM         RaspberryIO    ERROR System is not a Raspberry Pi
    Oct-07 11:53:59 AM         RaspberryIO    INFO RaspberryIO version 3.0.0.12
    Oct-07 11:48:32 AM         RaspberryIO    ERROR System is not a Raspberry Pi
    Oct-07 11:48:27 AM         RaspberryIO    INFO RaspberryIO version 3.0.0.12
    Oct-07 11:47:39 AM         RaspberryIO    ERROR System is not a Raspberry Pi
    Oct-07 11:47:34 AM         RaspberryIO    INFO RaspberryIO version 3.0.0.12
    Not really sure where to go from here.
    I think I need to add support for RPi 3B+ version
    Could you tell me what returns this command on your RPi:
     cat /proc/cpuinfo
    thanks
      Below is the output:
      admin@raspberrypi:~ $  cat /proc/cpuinfo
      processor       : 0
      model name      : ARMv7 Processor rev 4 (v7l)
      BogoMIPS        : 38.40
      Features        : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm crc32
      CPU implementer : 0x41
      CPU architecture: 7
      CPU variant     : 0x0
      CPU part        : 0xd03
      CPU revision    : 4
      processor       : 1
      BogoMIPS        : 38.40
      CPU architecture: 7
      CPU variant     : 0x0
      CPU part        : 0xd03
      CPU revision    : 4
      processor       : 2
      BogoMIPS        : 38.40
      CPU architecture: 7
      CPU variant     : 0x0
      CPU part        : 0xd03
      CPU revision    : 4
      processor       : 3
      BogoMIPS        : 38.40
      CPU architecture: 7
      CPU variant     : 0x0
      CPU part        : 0xd03
      CPU revision    : 4
      Hardware        : BCM2835
      Revision        : a020d3
      Serial          : 00000000b1cc0569
      Thank you!
        I added support for RPi 3B+ in version 3.0.0.13, that you can install from the Beta section of the updater, or there is a remote install package available here: https://www.dropbox.com/s/oaivpev2nn...l_3-0-0-13.zip
        Please test and let me know
          Running no problem now. Thanks for your help!
