Hello,
I am attempting to use the Raspberry Pi plugin and am having issues.
I am running HS3Pro on Windows 10. My Raspberry Pi 3 B+ is running Raspian Stetch. I have installed Mono 5.16 and mono-vbnc as sugested in other
forum entries. Initially I was able to get the plugin connected to the main HS3 and see the Remote plugin listed in HS3. I then went to the configure screen and changed a couple of the GPIO from Not used to Outputs. That seems to be where the problems began.
I have never seen the GPIO show up on the HS3 device list. I do have one entry that shows RaspberryPi however.
I am not sure how to view or send logs from the RPi or I would send them as well.
Any help would be appreciated.
Below is the log from HS3, filtered by RaspberrIO
Oct-15 8:06:09 PM RaspberryIO INFO Firmware rev10494163, board model B3Plus (Raspberry Pi 3 Model B+)
Oct-15 8:06:09 PM RaspberryIO INFO Serial number: 00000000282a94c0
Oct-15 8:06:09 PM RaspberryIO INFO Raspberry Pi running on Bcm2709 processor
Oct-15 8:06:03 PM RaspberryIO INFO RaspberryIO version 3.0.0.13
Oct-15 7:56:57 PM RaspberryIO INFO Serial number: 00000000282a94c0
Oct-15 7:56:57 PM RaspberryIO INFO Raspberry Pi running on Bcm2709 processor
Oct-15 7:56:57 PM RaspberryIO INFO Firmware rev10494163, board model B3Plus (Raspberry Pi 3 Model B+)
Oct-15 7:56:52 PM RaspberryIO INFO RaspberryIO version 3.0.0.13
Oct-15 7:56:18 PM RaspberryIO INFO Firmware rev10494163, board model B3Plus (Raspberry Pi 3 Model B+)
Oct-15 7:56:18 PM RaspberryIO INFO Serial number: 00000000282a94c0
Oct-15 7:56:18 PM RaspberryIO INFO Raspberry Pi running on Bcm2709 processor
Oct-15 7:56:12 PM RaspberryIO INFO RaspberryIO version 3.0.0.13
Oct-15 6:20:50 PM RaspberryIO ERROR System.ArgumentException: An item with the same key has already been added. Key: Pin2 at System.Collections.Generic.Dictionary`2[TKey,TValue].TryInsert (TKey key, TValue value, System.Collections.Generic.InsertionBehavior behavior) [0x000dd] in :0 at System.Collections.Generic.Dictionary`2[TKey,TValue].Add (TKey key, TValue value) [0x00000] in :0 at HSPI_RaspberryIO.RaspberryPiApp.b__49_0 () [0x004f2] in <4ede16bb2c524fc6a74653e3fb9eb675>:0
Oct-15 6:20:50 PM RaspberryIO INFO Raspberry Pi running on Bcm2709 processor
Oct-15 6:20:50 PM RaspberryIO INFO Firmware rev10494163, board model B3Plus (Raspberry Pi 3 Model B+)
Oct-15 6:20:50 PM RaspberryIO INFO Serial number: 00000000282a94c0
Oct-15 6:20:45 PM RaspberryIO INFO RaspberryIO version 3.0.0.13
Oct-15 6:20:13 PM RaspberryIO INFO RaspberryIO version 3.0.0.13
Oct-15 5:04:29 PM RaspberryIO ERROR System.ArgumentException: An item with the same key has already been added. Key: Pin2 at System.Collections.Generic.Dictionary`2[TKey,TValue].TryInsert (TKey key, TValue value, System.Collections.Generic.InsertionBehavior behavior) [0x000dd] in :0 at System.Collections.Generic.Dictionary`2[TKey,TValue].Add (TKey key, TValue value) [0x00000] in :0 at HSPI_RaspberryIO.RaspberryPiApp.b__49_0 () [0x004f2] in <4ede16bb2c524fc6a74653e3fb9eb675>:0
Oct-15 5:04:29 PM RaspberryIO INFO Firmware rev10494163, board model B3Plus (Raspberry Pi 3 Model B+)
Oct-15 5:04:29 PM RaspberryIO INFO Serial number: 00000000282a94c0
Oct-15 5:04:29 PM RaspberryIO INFO Raspberry Pi running on Bcm2709 processor
Oct-15 5:04:24 PM RaspberryIO INFO RaspberryIO version 3.0.0.13
Oct-15 5:03:50 PM RaspberryIO INFO RaspberryIO version 3.0.0.13
Oct-15 4:54:47 PM RaspberryIO INFO Firmware rev10494163, board model B3Plus (Raspberry Pi 3 Model B+)
Oct-15 4:54:47 PM RaspberryIO INFO Serial number: 00000000282a94c0
Oct-15 4:54:47 PM RaspberryIO INFO Raspberry Pi running on Bcm2709 processor
Oct-15 4:54:42 PM RaspberryIO INFO RaspberryIO version 3.0.0.13
Oct-15 4:54:09 PM RaspberryIO INFO Firmware rev10494163, board model B3Plus (Raspberry Pi 3 Model B+)
Oct-15 4:54:09 PM RaspberryIO INFO Serial number: 00000000282a94c0
Oct-15 4:54:09 PM RaspberryIO INFO Raspberry Pi running on Bcm2709 processor
Oct-15 4:54:04 PM RaspberryIO INFO RaspberryIO version 3.0.0.13
Oct-15 4:53:31 PM RaspberryIO INFO Serial number: 00000000282a94c0
Oct-15 4:53:31 PM RaspberryIO INFO Raspberry Pi running on Bcm2709 processor
Oct-15 4:53:31 PM RaspberryIO INFO Firmware rev10494163, board model B3Plus (Raspberry Pi 3 Model B+)
Oct-15 4:53:26 PM RaspberryIO INFO RaspberryIO version 3.0.0.13
Oct-15 4:52:54 PM RaspberryIO INFO Serial number: 00000000282a94c0
Oct-15 4:52:54 PM RaspberryIO INFO Raspberry Pi running on Bcm2709 processor
Oct-15 4:52:54 PM RaspberryIO INFO Firmware rev10494163, board model B3Plus (Raspberry Pi 3 Model B+)
Oct-15 4:52:49 PM RaspberryIO INFO RaspberryIO version 3.0.0.13
Oct-15 4:52:16 PM RaspberryIO INFO Raspberry Pi running on Bcm2709 processor
Oct-15 4:52:16 PM RaspberryIO INFO Firmware rev10494163, board model B3Plus (Raspberry Pi 3 Model B+)
Oct-15 4:52:16 PM RaspberryIO INFO Serial number: 00000000282a94c0
Oct-15 4:52:11 PM RaspberryIO INFO RaspberryIO version 3.0.0.13
Oct-15 4:51:38 PM RaspberryIO INFO Firmware rev10494163, board model B3Plus (Raspberry Pi 3 Model B+)
Oct-15 4:51:38 PM RaspberryIO INFO Serial number: 00000000282a94c0
Oct-15 4:51:38 PM RaspberryIO INFO Raspberry Pi running on Bcm2709 processor
Oct-15 4:51:33 PM RaspberryIO INFO RaspberryIO version 3.0.0.13
Oct-15 4:51:01 PM RaspberryIO INFO Firmware rev10494163, board model B3Plus (Raspberry Pi 3 Model B+)
Oct-15 4:51:01 PM RaspberryIO INFO Serial number: 00000000282a94c0
Oct-15 4:51:01 PM RaspberryIO INFO Raspberry Pi running on Bcm2709 processor
Oct-15 4:50:56 PM RaspberryIO INFO RaspberryIO version 3.0.0.13
Oct-15 4:50:23 PM RaspberryIO INFO Firmware rev10494163, board model B3Plus (Raspberry Pi 3 Model B+)
Oct-15 4:50:23 PM RaspberryIO INFO Serial number: 00000000282a94c0
Oct-15 4:50:23 PM RaspberryIO INFO Raspberry Pi running on Bcm2709 processor
Oct-15 4:50:18 PM RaspberryIO INFO RaspberryIO version 3.0.0.13
Oct-15 4:49:01 PM RaspberryIO ERROR System.ArgumentException: An item with the same key has already been added. Key: Pin2 at System.Collections.Generic.Dictionary`2[TKey,TValue].TryInsert (TKey key, TValue value, System.Collections.Generic.InsertionBehavior behavior) [0x000dd] in :0 at System.Collections.Generic.Dictionary`2[TKey,TValue].Add (TKey key, TValue value) [0x00000] in :0 at HSPI_RaspberryIO.RaspberryPiApp.b__49_0 () [0x004f2] in <4ede16bb2c524fc6a74653e3fb9eb675>:0
Oct-15 4:49:01 PM RaspberryIO INFO Raspberry Pi running on Bcm2709 processor
Oct-15 4:49:01 PM RaspberryIO INFO Firmware rev10494163, board model B3Plus (Raspberry Pi 3 Model B+)
Oct-15 4:49:01 PM RaspberryIO INFO Serial number: 00000000282a94c0
Oct-15 4:48:55 PM RaspberryIO INFO RaspberryIO version 3.0.0.13
Oct-15 4:48:23 PM RaspberryIO INFO RaspberryIO version 3.0.0.13
Oct-15 4:47:51 PM RaspberryIO INFO RaspberryIO version 3.0.0.13
Oct-15 4:47:18 PM RaspberryIO INFO Firmware rev10494163, board model B3Plus (Raspberry Pi 3 Model B+)
Oct-15 4:47:18 PM RaspberryIO INFO Serial number: 00000000282a94c0
