Error after move. ERROR System is not a Raspberry Pi
  • Error after move. ERROR System is not a Raspberry Pi
    Hi Spud,
    I hope your able to help. I'm lost without your plugin!
    Today I have moved my Homeseer install from an older server to something newer and faster.
    On the original server I had your plugin, version 3.0.0.12 and it worked fantastic.
    On the new server the updater installed 3.0.0.14.
    On starting the plugin I am getting the error ERROR System is not a Raspberry Pi
    The pi hasn't been changed at all. Just the Homeseer server. The pi details are:
    processor : 0
    model name : ARMv7 Processor rev 4 (v7l)
    BogoMIPS : 38.40
    Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt
    vfpd32 lpae evtstrm crc32
    CPU implementer : 0x41
    CPU architecture: 7
    CPU variant : 0x0
    CPU part : 0xd03
    CPU revision : 4
    processor : 1
    BogoMIPS : 38.40
    CPU architecture: 7
    CPU variant : 0x0
    CPU part : 0xd03
    CPU revision : 4
    processor : 2
    BogoMIPS : 38.40
    Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm crc32
    CPU architecture: 7
    CPU variant : 0x0
    CPU part : 0xd03
    CPU revision : 4
    processor : 3
    BogoMIPS : 38.40
    CPU architecture: 7
    CPU variant : 0x0
    CPU part : 0xd03
    CPU revision : 4
    Hardware : BCM2709
    Revision : a02082
    Serial : 00000000090be4ba
    where do you start the plugin?
    You don't need to start it on your HS3 server (and you shouldn't) if this HS3 server is not a RaspberryPi
    You only need to run the run.bat script from your Raspberry Pi
      Ah of course, I remember that now (been a long time since I originally set this up).
      But, on restarting Homeseer with the HS plugin turned off, but the Pi running, I'm not getting it appear?
        OK, all working now. I had forgotten that the pi had the IP address of the Homeseer server hard coded. Changed the IP to the old system IP and now all working.
        Thanks Spud
