Input pins will not trigger event
    tied 3.3v from pi, out to the ir trigger, made it nc on the ir device , under status, it show on, shut down the ir device set it to NO power it back up , the status shows off, it will not trigger an event no matter what I change, ran back and forth trying pull up/down/none revers on all there with no luck, running on windows HS with pi i/o, everything seem to be working, I can change settings in the windows hs app still no I/O event triggering, even tried to loop the input to ground just for a test, no luck there either any suggestions.......
