Does this work on the Raspberry Pi 4 (with Buster)
    Has this been tested on the Buster release that supports the Raspberry Pi 4?
    thank you,
    mike
    The Raspberry Pi 4 was just released a few days ago. Seems unlikely that anyone has one to test with so soon.
      I was lucky enough to reserve a Raspberry Pi 4 4GB at my local Micro Center on Thursday. Picked it up Friday and immediately took the leap and upgraded, got it working last night and this morning. I was coming from an RPi3 B+ on Stretch.
      I can report no issues specifically with Buster. Everything seems to be just the same as Stretch. Granted I'm not doing a lot, just went with the simple UI version (not Lite) as I wanted the option to use the UI later. I think installed the latest Mono, Webmin, copied over my old HS3 and used zwolfpack's "update-hs3" and other scripts and it pretty much worked. Granted I had similar challenges I've always had being far from a Linux expert, but there was nothing I can attribute to the new RPi4 or Buster. My X15 is not working, but I've had issues with mochad drivers before so I don't think it's Buster. I think I'm to the point where I can retire that one anyway.
      Webmin on my RPi3 was always 80+% memory usage with virtual memory very high as well. The new 4GB RPi4 has me currently at 16% RAM usage. Probably could have easily gone with the 2GB, but for just $10 more it gives me more flexibility.
      If anyone wants me to check anything, let me know.
      Ben
        I get "ERROR System is not a Raspberry Pi" when I run the plugin on my newly acquired Raspberry Pi 4 GB. Remote instances running on older Pis connect to HS3 running on the Pi 4 just fine.
        cat /proc/cpuinfo
        processor    : 0
        model name    : ARMv7 Processor rev 3 (v7l)
        BogoMIPS    : 108.00
        Features    : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm crc32
        CPU implementer    : 0x41
        CPU architecture: 7
        CPU variant    : 0x0
        CPU part    : 0xd08
        CPU revision    : 3
        processor    : 1
        BogoMIPS    : 108.00
        CPU architecture: 7
        CPU variant    : 0x0
        CPU part    : 0xd08
        CPU revision    : 3
        processor    : 2
        BogoMIPS    : 108.00
        CPU architecture: 7
        CPU variant    : 0x0
        CPU part    : 0xd08
        CPU revision    : 3
        processor    : 3
        BogoMIPS    : 108.00
        CPU architecture: 7
        CPU variant    : 0x0
        CPU part    : 0xd08
        CPU revision    : 3
        Hardware    : BCM2835
        Revision    : b03111
        Serial        : 10000000a58e1fe8
          I have just added support for Raspberry Pi 4 in version 3.0.0.16
          It's available from the Beta section of the updater, or the remote install archive can be downloaded from: https://www.dropbox.com/s/x7ma2bshqa...-0-16.zip?dl=0
          I don't have a RPi 4 to test with, so let me know how it goes. Thanks!
            Thanks, that works perfectly!
              Setup a Pi mono with Raspian/Debian 10.2 and this is what I needed to do to install Mono and it worked fine with .17 version of plugin! :-D sudo apt-get install mono-devel sudo apt-get install mono-complete sudo apt-get install mono-vbnc
