I have RaspberryIO running on a RaspberryPi 4 with HS3 on a Windows 10 pc with the plugin disabled and everything works great.
I wanted to run a second instance of RaspberryIO on a second RaspberryPi 4. I installed NOOBS on a new RaspberryPi 4 and went thru the upgrade process. I then installed Mono-complete and mono-vbnc.
Next, I installed the RaspberryIO the second Pi according to the user guide. I used a different instance name this time.
When I start RaspberryIO on the second Pi, I get the following error:
Plugin: RaspberryIO Instance: RemoteGPIO2 starting...
Connection attempt #1
Connected (Homeseer API 3). Waiting to be initialized...
Feb-20 10:19:54 INFO RaspberryIO version 3.0.0.17
Feb-20 10:19:59 ERROR System is not a Raspberry Pi
I though I did everything the same as on the first Pi which is running great.
I also tried shutting down the Pi that was working and then started the second Pi with the same result.
I am doing something wrong, but I do not know what it is.
