ERROR System.IO.FileNotFoundException
    I am very new to the Raspberry Pi environment on HS3. I have a Pi Model 3B+ running Raspian "Buster" Desktop Lite.
    Today I installed RaspberryIO on HS3, version: HS3 Standard Edition 3.0.0.548 (Windows)
    The plugin installed without any errors or warnings on HS3
    I followed the Raspberry IO User's guide instructions for installing RaspberryIO and Mono on the Pi.
    I followed this guide to install Mono on the Pi: Howto upgrade Mono to version 4.x on a Raspberry Pi After editting the sources.list on the Pi to include this line: deb http://download.mono-project.com/repo/debian wheezy/snapshots 4.2.3.4/main and then ran these two lines on the pi:
    sudo apt-get update
    sudo apt-get upgrade
    I got an error running the upgrade line. After looking thru the RaspberryIO forum I found another user that was getting errors upgrading and found an entry saying:
    if you added the line at the end of sources.list, just remove it. Then:
    sudo apt-get update sudo apt-get install mono-complete I did that and Mono installed on the Pi.
    When I ran the code for the first time from the pi using "sudo ./run.sh", I see this output in the terminal window on the pi:
    pi@test-genmon-pi:~/RaspberryIO $ sudo ./run.sh
    Plugin: RaspberryIO Instance: TestRemote starting...
    Connecting to server at 192.168.0.4...
    Connection attempt #1
    Connected (HomeSeer API 3). Waiting to be initialized...
    Apr-08 14:09:09 INFO RaspberryIO version 3.0.0.18
    Apr-08 14:09:09 ERROR System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies.
    File name: 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a'
    at HSPI_RaspberryIO.WebConfig..ctor (System.String pageName) [0x0000b] in <c1cfcbc3de1842779a632698b5a3e76a>:0
    at HSPI_RaspberryIO.RaspberryPiApp.Init () [0x00090] in <c1cfcbc3de1842779a632698b5a3e76a>:0
    Apr-08 14:09:09 INFO Shutting Down plug-in
    Shutdown IO called
    Connection lost, exiting
    Error SendInvokeResponse: Client is not connected to the server.
    Disconnected from server - client
    Waiting 30 seconds before trying to reconnect
    I am also seeing these errors in the HS3 log:
    Apr-08 2:09:06 PM
    RaspberryIO
    Apr-08 2:09:06 PM
    Error
    Initializing plug-in(1): RaspberryIO Instance:TestRemote:System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. File name: 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' at HSPI_RaspberryIO.WebConfig..ctor (System.String pageName) [0x0000b] in :0 at HSPI_RaspberryIO.RaspberryPiApp.Init () [0x00090] in :0 Time to load: 151 milliseconds
    Apr-08 2:09:06 PM
    RaspberryIO
    ERROR System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. File name: 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' at HSPI_RaspberryIO.WebConfig..ctor (System.String pageName) [0x0000b] in :0 at HSPI_RaspberryIO.RaspberryPiApp.Init () [0x00090] in :0
    Apr-08 2:09:06 PM
    RaspberryIO
    Apr-08 2:09:06 PM
    Starting Plug-In
    Initializing plugin RaspberryIO ...
    Apr-08 2:09:06 PM
    Info
    Plugin RaspberryIO with instance TestRemote has connected. IP:192.168.0.69:35088
    Can you help me figure out what I have done wrong?
    you need to install the vbnc package:
     sudo apt-get install mono-vbnc
      That did it! Everything appears to be working. Thanks for that very quick response.
      Being a newbie to Linux, I have to ask, What do these three installs do?
      sudo apt-get install mono-devel
        it installs all the mono libraries you need to run the plugin.
          Thank you. I think I am going to like this plugin and the additional digital I/O integration it brings to to HS.
