When a CAPI command such as shown below is executed to turn Off DeviceA and is immediately followed by the WriteLog command shown, the WriteLog statement shows DeviceA Value still equal to 1.
Immediately following the WriteLog after the CAPI Off command, I then execute the For Loop as shown.
After 50 to 100 times through the loop(the number varies some each time the code is run), the Value of DeviceA finally becomes = 0 as expected.
I am assuming this delay in the value changing from 1 to 0 is the time for the RaspberryIO Plugin to receive the CAPI command and update the value back to Homeseer.
Immediately after the CAPI Off command, Homeseer still shows the Value = 1 when it should b = 0.
In my actual code, immediately after the CAPI command, there is code to act on the CAPI result and the code produces the wrong results, because it still sees DeviceA value = 1.
Does anyone know a solution to this timing issue?
hs.CAPIControlHandler(hs.CAPIGetSingleControl(hs.GetDeviceRe fByName("RaspberryIO DeviceA"), True, "Off", False, False))
hs.WriteLog("Debug", "After CAPI Off-DeviceA Value = " & hs.DeviceValueByName("RaspBerryIO DeviceA").ToString)
Dim i as Integer
For i = 1 to 100
hs.WriteLog("Debug", "Loop-DeviceA Value = " & hs.DeviceValueByName("RaspBerryIO DeviceA").ToString)
next i
Dim i as Integer
For i = 1 to 100
next i
