I have been using the RaspberryIO Plugin for about 6 months with no issues. I use the Rasperry Pi and RaspberryIO Plugin to run a Sprinkler Controller with Homeseer Scripts. The Raspberry Pi quit responding, so I rebooted the Raspberry Pi and re-started RaspBerryIO. It worked for a while and quit working again. I have done this several times. This morning, when I rebooted the RaspberryPi and then re-start RaspberryIO, I get multiple lines of error messages from the RaspberryPi terminal session stating: ERROR Cannot change pin value when GPIO connection is null. A screen shot is attached. Any help would be most appreciated.
RaspberryIO Startup Error
Thanks for the question, but the wiring is solid. When the Plugin quits working, and I click on the RaspberryIO entry under Homeseer Plugins, I get a bad URL request and the RaspberryIO entry under Plugins goes away. I restart the Pi and restart the RaspberryIO Plugin and it will work for several minutes to several hours or sometimes when starting RaspberryIO, I get the GPIO errors I listed in the first post.does not
