No devices in HS4
    No devices in HS4
    Hi Spud/All,
    I'm setting up a fresh install of HS4. I currently use this plugin on my HS3 installation. Before adding the plugin to HS4 I made sure HS3 was completely shut down.
    Added the plugin no problem and the PI connected to the plugin. I then configured a couple of my input devices. They seems to take OK, but I don't appear to have corresponding devices?
    I have the following errors in the log...
    13/08/2020 12:57:20
    HomeSeer
    Warning
    Device (212) RaspIO RaspberryIO Shed Rear PIR Input references a parent, but the parent does not exist
    13/08/2020 12:57:20
    HomeSeer
    Warning
    Issue checking child device (212) RaspIO RaspberryIO Shed Rear PIR Input
    13/08/2020 12:57:20
    HomeSeer
    Warning
    Device (211) RaspIO RaspberryIO West Garden PIR Input references a parent, but the parent does not exist
    13/08/2020 12:57:20
    HomeSeer
    Warning
    Issue checking child device (211) RaspIO RaspberryIO West Garden PIR Input
    13/08/2020 12:57:20
    HomeSeer
    Warning
    Device (210) RaspIO RaspberryIO Driveway Break Beam Input references a parent, but the parent does not exist
    13/08/2020 12:57:20
    HomeSeer
    Warning
    Issue checking child device (210) RaspIO RaspberryIO Driveway Break Beam Input
    13/08/2020 12:57:20
    HomeSeer
    Warning
    Device (209) RaspIO RaspberryIO Gate Door Input references a parent, but the parent does not exist
    13/08/2020 12:57:20
    HomeSeer
    Warning
    Issue checking child device (209) RaspIO RaspberryIO Gate Door Input
    Any help appreciated.
    I tried adding another device with debug enabled..
    13/08/2020 13:12:42
    Legacy-Plugin
    RaspberryIO
    DEBUG Pin5 value changed to Off
    13/08/2020 13:12:42
    Legacy-Plugin
    RaspberryIO
    DEBUG Resetting connection to update Reversed flag for Pin5
    13/08/2020 13:12:42
    Legacy-Plugin
    RaspberryIO
    DEBUG Setting Reversed flag to True for Pin5
    13/08/2020 13:12:41
    Legacy-Plugin
    RaspberryIO
    DEBUG Pin5 value changed to On
    13/08/2020 13:12:41
    Legacy-Plugin
    RaspberryIO
    DEBUG Resetting connection to update resistor for Pin5
    13/08/2020 13:12:41
    Legacy-Plugin
    RaspberryIO
    DEBUG Setting Resistor to PullUp for Pin5
    13/08/2020 13:12:39
    Legacy-Plugin
    RaspberryIO
    DEBUG Setting name to test for Pin5
    13/08/2020 13:12:39
    Legacy-Plugin
    Z-Wave
    Starting Z-Wave Polling for Network 000162FD...
    13/08/2020 13:12:37
    Legacy-Plugin
    RaspberryIO
    13/08/2020 13:12:37
    Legacy-Plugin
    RaspberryIO
    DEBUG Setting direction to Input for Pin5
    13/08/2020 13:12:28
    Legacy-Plugin
    RaspberryIO
    DEBUG Setting name to Gate Door Input for Pin2
    13/08/2020 13:12:28
    Legacy-Plugin
    RaspberryIO
    DEBUG Setting pulse duration to 1000ms for Pin2
    13/08/2020 13:12:28
    Legacy-Plugin
    RaspberryIO
    DEBUG Pin2 value changed to Off
    13/08/2020 13:12:28
    Legacy-Plugin
    RaspberryIO
    DEBUG Setting Resistor to PullUp for Pin2
    13/08/2020 13:12:28
    Legacy-Plugin
    RaspberryIO
    DEBUG Setting Reversed flag to True for Pin2
    13/08/2020 13:12:28
    Legacy-Plugin
    RaspberryIO
    DEBUG Setting direction to Input for Pin2
    13/08/2020 13:12:28
    Legacy-Plugin
    RaspberryIO
    DEBUG Setting name to Shed Rear PIR Input for Pin27
    13/08/2020 13:12:28
    Legacy-Plugin
    RaspberryIO
    DEBUG Setting pulse duration to 1000ms for Pin27
    13/08/2020 13:12:28
    Legacy-Plugin
    RaspberryIO
    DEBUG Pin27 value changed to Off
    13/08/2020 13:12:28
    Legacy-Plugin
    RaspberryIO
    DEBUG Setting Resistor to PullUp for Pin27
    13/08/2020 13:12:28
    Legacy-Plugin
    RaspberryIO
    DEBUG Setting Reversed flag to True for Pin27
    13/08/2020 13:12:28
    Legacy-Plugin
    RaspberryIO
    DEBUG Setting direction to Input for Pin27
    13/08/2020 13:12:28
    Legacy-Plugin
    RaspberryIO
    DEBUG Setting name to West Garden PIR Input for Pin4
    13/08/2020 13:12:28
    Legacy-Plugin
    RaspberryIO
    DEBUG Setting pulse duration to 1000ms for Pin4
    13/08/2020 13:12:28
    Legacy-Plugin
    RaspberryIO
    DEBUG Pin4 value changed to Off
    13/08/2020 13:12:28
    Legacy-Plugin
    RaspberryIO
    DEBUG Setting Resistor to PullUp for Pin4
    13/08/2020 13:12:28
    Legacy-Plugin
    RaspberryIO
    DEBUG Setting Reversed flag to True for Pin4
    13/08/2020 13:12:28
    Legacy-Plugin
    RaspberryIO
    DEBUG Setting direction to Input for Pin4
    13/08/2020 13:12:28
    Legacy-Plugin
    RaspberryIO
    DEBUG Setting name to Driveway Break Beam Input for Pin03
    13/08/2020 13:12:28
    Legacy-Plugin
    RaspberryIO
    DEBUG Setting pulse duration to 1000ms for Pin03
    13/08/2020 13:12:28
    Legacy-Plugin
    RaspberryIO
    DEBUG Pin03 value changed to Off
    13/08/2020 13:12:28
    Legacy-Plugin
    RaspberryIO
    DEBUG Setting Resistor to PullUp for Pin03
    13/08/2020 13:12:28
    Legacy-Plugin
    RaspberryIO
    DEBUG Setting Reversed flag to True for Pin03
    13/08/2020 13:12:28
    Legacy-Plugin
    RaspberryIO
    DEBUG Setting direction to Input for Pin03
    13/08/2020 13:12:27
    Legacy-Plugin
    RaspberryIO
    INFO Serial number: 00000000090be4ba
    13/08/2020 13:12:27
    Legacy-Plugin
    RaspberryIO
    INFO Firmware rev10494082, board model B3 (Raspberry Pi 3 Model B)
    13/08/2020 13:12:27
    Legacy-Plugin
    RaspberryIO
    INFO Raspberry Pi running on Bcm2710 processor
      Can't see anything failing but once again, no device created.
        Hi.
        I've got the same problem.
        New fresh HS4 install, it was working on HS3 earlier today.
        The plugin connects, and it seems that the config goes trough to the raspberry...(Checked on the raspberry with GPIO readall, and the mode (output and input) on the GPIO are correct.
        But no devices appears.
        Also got this error in the log
        17.08.2020 15:27:12
        Legacy-Plugin
        RaspberryIO
        ERROR System is not a Raspberry Pi
        17.08.2020 15:27:11
        HomeSeer
        Info
        No device issues found
        17.08.2020 15:27:11
        HomeSeer
        Warning
        Device (177) honsehus RaspberryIO U2 references a parent, but the parent does not exist
        17.08.2020 15:27:11
        HomeSeer
        Warning
        Issue checking child device (177) honsehus RaspberryIO U2
        17.08.2020 15:27:11
        HomeSeer
        Warning
        Device (176) honsehus RaspberryIO B1 references a parent, but the parent does not exist
        17.08.2020 15:27:11
        HomeSeer
        Warning
        Issue checking child device (176) honsehus RaspberryIO B1
        17.08.2020 15:27:11
        HomeSeer
        Warning
        Device (175) honsehus RaspberryIO R2 references a parent, but the parent does not exist
        17.08.2020 15:27:11
        HomeSeer
        Warning
        Issue checking child device (175) honsehus RaspberryIO R2
        17.08.2020 15:27:11
        HomeSeer
        Warning
        Device (174) honsehus RaspberryIO R1 references a parent, but the parent does not exist
        17.08.2020 15:27:11
        HomeSeer
        Warning
        Issue checking child device (174) honsehus RaspberryIO R1
        17.08.2020 15:27:11
        HomeSeer
        Warning
        Device (173) honsehus RaspberryIO U1 references a parent, but the parent does not exist
        17.08.2020 15:27:11
        HomeSeer
        Warning
        Issue checking child device (173) honsehus RaspberryIO U1
        17.08.2020 15:27:11
        HomeSeer
        Warning
        Device (172) honsehus RaspberryIO R8 references a parent, but the parent does not exist
        17.08.2020 15:27:11
        HomeSeer
        Warning
        Issue checking child device (172) honsehus RaspberryIO R8
        17.08.2020 15:27:11
        HomeSeer
        Warning
        Device (171) honsehus RaspberryIO R7 references a parent, but the parent does not exist
        17.08.2020 15:27:11
        HomeSeer
        Warning
        Issue checking child device (171) honsehus RaspberryIO R7
        17.08.2020 15:27:11
        HomeSeer
        Warning
        Device (170) honsehus RaspberryIO B2 references a parent, but the parent does not exist
        17.08.2020 15:27:07
        HomeSeer
        Starting Plug-In
        Plugin RaspberryIO started successfully in 36 milliseconds
        17.08.2020 15:27:07
        Legacy-Plugin
        RaspberryIO
        INFO RaspberryIO version 3.0.0.18
        17.08.2020 15:27:07
        HomeSeer
        Starting Plug-In
        Initializing plugin RaspberryIO ...
        17.08.2020 15:27:07
        HomeSeer
        Info
        Plugin RaspberryIO has connected. IP:127.0.0.1:52519
          Don't now why, but during the evening, the devices got in. First found them with a mobile device, and checked with a browser afterwards. Have been excluding and importing z-wave devices during the evening. Can't find anything in the log that can explain this eighter.
            I'm still not getting any devices. I started a fresh config in HS4 and reset the plugin. Restarted HS4 and the pi connected no problem. Went into config and set GPIO2 as an input.
            Unfortunately nothing in devices. That was several days ago and still nothing
            spud ? Any help please? I can't go to HS4 until I get my IO working
              I've seen this in the log.. thought it might be related but doesn't seem to coincide with me working on the plugin devices.
              18/08/2020 10:29:22
              HomeSeer
              Error
              Saving database: Value cannot be null. Parameter name: collection
              18/08/2020 13:19:06
              HomeSeer
              Warning
              Device (6) RaspIO RaspberryIO Shed Rear PIR references a parent, but the parent does not exist
              18/08/2020 13:19:06
              HomeSeer
              Warning
              Issue checking child device (6) RaspIO RaspberryIO Shed Rear PIR
              18/08/2020 13:19:06
              HomeSeer
              Warning
              Device (5) RaspIO RaspberryIO West Garden PIR references a parent, but the parent does not exist
              18/08/2020 13:19:06
              HomeSeer
              Warning
              Issue checking child device (5) RaspIO RaspberryIO West Garden PIR
              18/08/2020 13:19:06
              HomeSeer
              Warning
              Device (4) RaspIO RaspberryIO Driveway Break Beam references a parent, but the parent does not exist
              18/08/2020 13:19:06
              HomeSeer
              Warning
              Issue checking child device (4) RaspIO RaspberryIO Driveway Break Beam
              18/08/2020 13:19:06
              HomeSeer
              Warning
              Device (3) RaspIO RaspberryIO Gate Door references a parent, but the parent does not exist
              18/08/2020 13:19:06
              HomeSeer
              Warning
              Issue checking child device (3) RaspIO RaspberryIO Gate Door
              18/08/2020 13:19:06
              HomeSeer
              Info
              Checking device parent child relationships...
                I think I've got somewhere.
                Because I am running HS3 and HS4, I first shutdown HS3 and then fired up HS4 to configure.
                When HS4 starts the Raspberry PI connects to the plugin. But, no devices were ever created.
                What I didn't do was to restart the PI. So, I shutdown HS4 and restarted the PI then restarted HS4 and it now appears to be working.
                  Sorry for the delay, I'm on vacation.
                  Glad you got it to work. That being said for a remote install of the RaspberyyIO plugin to work 100% with HS4, you may need to copy the following dll from your HS4 dir to your RapsberryIO install dir:
                  • HSCF.dll
                  • HomeSeerAPI.dll
                  • Scheduler.dll
                    No worries Spud, appreciate you getting back to me
                    I'll copy those files, thanks for the heads up.
