Contacting HomeSeer This Week
See more
See less
RaspberryIO - Beta Testing
This is a sticky topic.
  • #61
    Originally posted by alexbk66 View Post
    the spud, while working on my own plugin, I found that to display the plugin name in remote section you need to call
    Callback.RegisterConfigLink(wpd);
    You can set link to "http://192.168.0.14/raspberryioconfig?instance=RasPi"
    Click image for larger version Name:	Capture.PNG Views:	1 Size:	46.7 KB ID:	1274755
    Interesting though why for my plugin there's "Disconnect" button? And for yours - "N/A"?
    Thanks for the info. I had removed the call to RegisterConfigLink for named instances because there used to be a bug in HS3 that made the link wrong, but it looks like it works now so I can put it back.
    It looks like the Disconnect button only appears if the remote instance doesn't have a name.
    • #62
      One possible request. Since it takes a while to initialise the plugin - would be nice to know when it's ready. Possibly use the root device - set its status when disconnected/reconnected/initialised? I assume it's instance root, not plugin?
      • #63
        Mr Spud,
        Today, I have purchased new Raspberry Pi 3 B+ and Im wondering if you have solution to connect Raspberry board to the internet with sim card.
        My intentions are to use this board in remote location.
        I'm not programmer, but I'm good with wires.
        Any help is appreciated.
        Sent from my EML-L09 using Tapatalk
        • #64
          Originally posted by Tim View Post
          Mr Spud,
          I guess you would need something like this: https://sixfab.com/product/raspberry...te-shield-kit/
          I have never tested such a thing.
          • #65
            This seems to have been asked a couple of times without an answer... Is it possible to monitor the connection status?
            Currently I use the arduino and I know if the boards are connected or not. Is there any way to have this capability with the RPI plugin?
            • #66
              I dedicated one input and one output - jumped tigether, loopback - for monitoring connection. Trigger event every two seconds, if input isn't updated in 5 seconds - send Pushover message.
              • #67
                If by connection status you mean the connection between the remote plugin and HS3, it's not possible because the plugin runs on the RPi so once it is disconnected it can't update a device status on HS3
                • #68
                  OK thanks...
                  On the topic of RPI disconnections.... I have noticed that if I take my RPI offline, then try to get to the Plugins page on HS it takes about 5 minutes before the page loads.
                  Is that normal?
                  • #69
                    One question, how to verify on RasPi if the plugin is running? I was expecting "ps -ae | grep mono" to show - but it doesn't.
                    • #70
                      When I upgrade my ZEE S2 to HS4, will your plug-in continue to work?
                      • #71
                        Yes the plugin will continue to work with HS4
                        • #72
                          Thank you!
                          I am using your plug-in on an RPi with an 8-channel relay in my RV to control various DC loads - primarily lighting. Love it!
                          • #73
                            Hey Spud,
                            I am just trying to test your RaspberryIO on my system. I want to run it as a remote, however when I wget the files it always downloads the exe's instead.
                            2. download the plug-in remote install archive and unzip it. (This archive contains the plug-in files and the Homeseer libraries needed to run a plug-in remotely)
                            wget https://www.dropbox.com/s/jql5rcyu9p...O_3-0-0-17.zip unzip RaspberryIO_remote_install_3-0-0-17.zip Here is the conversation,
                            root@raspberrypi:/var/RaspberryIO# wget https://www.dropbox.com/s/jql5rcyu9p...O_3-0-0-17.zip
                            --2019-12-10 06:49:43-- https://www.dropbox.com/s/jql5rcyu9p...O_3-0-0-17.zip
                            Resolving www.dropbox.com (www.dropbox.com)... 162.125.11.1, 2620:100:6050:1::a27d:b01
                            Connecting to www.dropbox.com (www.dropbox.com)|162.125.11.1|:443... connected.
                            HTTP request sent, awaiting response... 301 Moved Permanently
                            Location: /s/raw/jql5rcyu9pl7jjq/RaspberryIO_3-0-0-17.zip [following]
                            --2019-12-10 06:49:43-- https://www.dropbox.com/s/raw/jql5rc...O_3-0-0-17.zip
                            Reusing existing connection to www.dropbox.com:443.
                            HTTP request sent, awaiting response... 302 Found
                            Location: https://uc317c638fd9cb7a15fa7e55062a...z45s3CPM/file# [following]
                            --2019-12-10 06:49:43-- https://uc317c638fd9cb7a15fa7e55062a...7z45s3CPM/file
                            Resolving uc317c638fd9cb7a15fa7e55062a.dl.dropboxusercontent.com (uc317c638fd9cb7a15fa7e55062a.dl.dropboxusercontent.com)... 162.125.11.6, 2620:100:6050:6::a27d:b06
                            Connecting to uc317c638fd9cb7a15fa7e55062a.dl.dropboxusercontent.com (uc317c638fd9cb7a15fa7e55062a.dl.dropboxusercontent.com)|162 .125.11.6|:443... connected.
                            HTTP request sent, awaiting response... 302 FOUND
                            Location: /cd/0/inline2/At-16qELn-MJ9XgHFVwM3SuucvZYcJkmXTnGZWsWMIpcZ2La4iOBg4mZ9ReNMaC9bf8PeX btgmatc5-NFiy49vXNsK9jb6QdcQC3UOqNgL-F-A_EFFUxdtvrAfQxOTojt7TY7MJd1uKYMhxcXMIlYjUWlqZ2CJ7ZH5eE9ol4I 61cJ7k-dMusJN4MDcVu5-C2ejY1s7MuEnOG2iGwlk2QsxQTyp224BLphxd7XDGxgZyL6npVSSYoXPoQTQ 7WE8s-CfwKa1g0A9xFPOnwLrXbRTvE1yMQXEbkWtuhoTjoDaAbjL8KWgHQ5ihemn76 BgMG-mDGen3Nref3Bp0Bu1P4c4Wd4daQeucwThgetC2OmcBnWQ/file [following]
                            --2019-12-10 06:49:44-- https://uc317c638fd9cb7a15fa7e55062a...C2OmcBnWQ/file
                            Reusing existing connection to uc317c638fd9cb7a15fa7e55062a.dl.dropboxusercontent.com:443.
                            HTTP request sent, awaiting response... 200 OK
                            Length: 595901 (582K) [application/zip]
                            Saving to: ‘RaspberryIO_3-0-0-17.zip’
                            RaspberryIO_3-0-0-1 100%[=====================>] 581.93K 1.30MB/s in 0.4s
                            2019-12-10 06:49:45 (1.30 MB/s) - ‘RaspberryIO_3-0-0-17.zip’ saved [595901/595901]
                            • #74
                              Originally posted by smithdavee View Post
                              Hey Spud,
                              I'm not sure I understand your problem. What exe file?
                              The zip file contains HSPI_RaspberryIO.exe. It can look strange to have an .exe on Linux, but mono can run .exe files, so it's ok.
                              • #75
                                This is what I get when I put the zip on the Pi box.
                                root@raspberrypi:/var/RaspberryIO# unzip RaspberryIO_3-0-0-17.zip
                                Archive: RaspberryIO_3-0-0-17.zip
                                inflating: HSPI_RaspberryIO.exe
                                inflating: HSPI_RaspberryIO.exe.config
                                inflating: images.zip
                                inflating: install.txt
                                inflating: Raspberry.IO.dll
                                inflating: Raspberry.IO.GeneralPurpose.dll
                                inflating: Raspberry.IO.Interop.dll
                                inflating: Raspberry.System.dll
                                extracting: RaspberryIO.ini
                                According to the documentation there should be a run.sh file. It doesn't exist.
                                Confused!!!
