Here is a method that worked for me on Raspbian
Note: this method only work for RPi 2 and 3, for RPi 1 and RPi Zero use this guide instead.
remove current mono version:
Add the Mono Project GPG signing key to your system
Edit the sources.list file to Add the Mono package repository to your system
Add the following line at the end of the file and save
update and upgrade your system
reinstall mono
check the version you are now running:
sudo apt-get purge mono-runtime sudo apt-get autoremove
sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys 3FA7E0328081BFF6A14DA29AA6A19B38D3D831EF
sudo nano /etc/apt/sources.list
deb http://download.mono-project.com/repo/debian wheezy/snapshots 4.2.3.4/main
sudo apt-get update sudo apt-get upgrade
sudo apt-get install mono-devel sudo apt-get install mono-complete sudo apt-get install mono-vbnc
mono --version
