Reading 1-Wire devices?
  • Reading 1-Wire devices?
    Hi,
    Not done much research into this yet so sorry if it's a simple question.
    Is there a way of reading 1-Wire Temperature sensors using this plugin?
    I have already connected simple on/off style sensors by reading the inputs. But the 1 Wire sensors actually send data rather than simple values.
    Thanks, Matt.
    no sorry, the plugin only supports digital (=on/off) inputs/outputs
      You could do it with Python relatively easily - I posted some Python code here (been a while since I looked at it), you'd just need to run the python code in a loop which I am not sure how to do from HS but some Linux guru would know.
      http://forums.homeseer.com/showpost....0&postcount=38
        That's fine. Will knock up a Python script to do it. Give me an excuse to play around with the Homeseer JSON functionality .
          Did you ever get this to work? I'd like to use one-wire on a 'remote' pi and have it show as a HomeSeer device.
          **** Do You "Cocoon"? ****
