Looks like you have first version of Raspberian Wheezy on your two RPi's. That said the first Homeseer Zee ran on an RPi #1.
The initial Homeseer 3 Zee 2 had mono that was built long math way which made it difficult to remove.
Tim,
It will be easier for you to start from scratch. That said you will lose your events as mentioned above using a newer version of Mono.
Best maybe to save your Homeseer 3 directory to a USB stick. Copy /opt/usr/HomeSeer to a USB stick. Make sure it is not running.
1 - Download current version of Zee2 over here ==> Download Zee2
2 - write the image to a new 16 SD card and connect a monitor and keyboard to your RPi
3 - after install make sure it is running.
4 - update and upgrade the OS
5 - at the end check your version of mono: mono -V
6 - this version of Mono on the new Zee2 can be upgraded if you want. (optional).
As mentioned above you will lose your events upgrading Mono versions. There are no real mechanisms to preserve you events when upgrading old mono to new mono.
Best mechanism is to do a screen print maybe of each of your events and manually re-enter them one by one.
Here repurposed my original Homeseer 3 Zee and continue to utilize the Zee 2 RPi2's.
Tim,
