The SimpleHomeNet Plugin has been updated to include basic support of the digital/analog inputs in analog mode on the EZIO2X4, EZIO8SA and EZIO6I.
The beta version of the plugin includes the following updates/additions:
Please let me know if you have any questions,
Adam
- Improved Add Devices screen
- Removed spurious log messages
- Added ability to get and set analog transition thresholds (the analog thresholds screen will take a few seconds to load)
- There is some timing that is out of my control that may cause the thresholds screen to not load and display an error message. If you receive this error message, please try loading the screen again.
- The analog inputs are converted using a 10-bit A/D conversion. The 10-bit A/D converter results in 1024 voltage ranges (0-1023).
- The EZIO device will send out a broadcast notification when the relevant threshold has been exceeded and the associated device in HomeSeer will be updated accordingly.
- Added ability to set the conversion mode of the digital/analog inputs:
- Digital (the inputs stay in digital mode and transition between OFF and ON at fixed intervals)
- Manual (the analog value is only read when commanded)
- Continuous (the analog value is read at fixed intervals of 1 second)
- Currently there is no difference in the plugin between these two modes. The ability to view the analog value as read at the input port will be added to a future version.
- Added abilty to enable debounce of analog inputs:
- The debounce function applies a filter to the analog input that minimizes ripples and noise that may cause false readings.
- Shutdown HomeSeer
- Rename the existing HSPI_SimpleHomeNet.dll to HSPI_SimpleHomeNet.bak
- Copy the HSPI_SimpleHomeNet.dll from the attached ZIP file to the HomeSeer directory
- Restart HomeSeer
Adam
