So, since I upgraded to HS3, I've had some issues with the SimpleHomeNet plug-in. For the first couple of days after upgrading, my EZIO didn't work at all with the plug-in, but was eventually found on the network.
However, now, it works maybe 2/7ths of the time (about 2 days a week). The rest of the time, I don't get any notifications from the device and the plug-in is mostly silent except for if I restart HS3 I get the error "Error transmitting message to read input port for device with address 19.BA.C7"
If I try to read the analog values from within the plug-in, I get the error "error transmitting message to set peek value to 13 for device with address 19.BA.C7" in the log and the plug-in page keeps refreshing "Loading threshold data..." until it finally displays "Error getting data from device".
I posted about this a couple months ago when I originally upgraded to HS3, but the issue resolved itself within a few days. Now, however, it's been happening again for the past ~month and I've just been blowing it off due to busy schedules.
From the SimpleHomeNet utility, I have 100% reliability where any time I open the utility I can connect to the EZIO. Also, when I had HS2, I had about 100% reliability as well.
The EZIO is plugged into the socket on the front of my 2413U PLM and has been for a few years, so I don't think it's a network connectivity issue.
EDIT: FYI, I am running Mark's Insteon plug-in v3.0.5.20 and v2.0.0.0 of the SimpleHomeNet plug-in.
In the Insteon plug-in I can see "Externally registered device: 19.BA.C7 (Insteon Address 19.BA.C7) registered through method"
